First Fall Fertilizer On Newly Sodded Lawn - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-02-2015, 10:56 AM   #1
Rewards Points: 145
First Fall Fertilizer on Newly Sodded Lawn
In May we had all new sod installed and it took really well (Boston). I did one application of milorganite in July and it really greened up but lately with the heat it's either browning or starting to go dormant? We've gotten decent amounts of rain but I've kept up with 1" a week of watering. I also have a section that is shaded where it seems to have a lot of thatching or dead growth. I've gotten a test kit so I hope to figure where it stands with Ph, N, etc.
I'm thinking in the coming weeks it needs:
Aeration Power & raking at first fall dew
Application of fertilizer specs TBD
Seeding with light layer of compost and starter fertilizer in thin areas
Mow at lowest level for last mowing
Any other things I should know about? I'll try and post some pictures tonight.
Thanks.
kjmass1 is offline   Reply With Quote
Old 09-02-2015, 01:54 PM   #2
Rewards Points: 6,997
Aeration Power & raking are the last thing you want to do with new sod which has under developed roots.
Application of fertilizer specs TBD A good balanced feeding something with equal numbers or higher for the last two. You want to promote root growth so you can grow the top next spring.
Seeding with light layer of compost Compost never hurts if applied lightly.
Mow at lowest level for last mowing Again not to smart grass should never be cut to less than 3" in height.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 09-02-2015, 04:37 PM   #3
PE Mechanical Engineer
Thunder Chicken's Avatar
Rewards Points: 862
You probably don't want (or need) to aerate and power rake sod after its first season - there probably isn't much thatch to speak of and the roots might still be a bit weak (i.e. you risk peeling up sections of your lawn).
I'd also not mow right now in the dry heat that we have been getting. Your grass is going dormant in the heat (normal). Chemical fertilizer is a bad idea now as it will probably burn the grass, but you can top dress with compost and keep it watered; that would help keep it cool and moist. Just wait until the fall weather rolls in and do a final mow and quick cleanup.
Never ever mow low - mow as high as you can, always. Mowing low just stresses the grass and gives weeds a chance.
Thunder Chicken is offline   Reply With Quote
Old 09-02-2015, 04:50 PM   #4
Rewards Points: 145
I thought I read something about mowing low(obviously not scalping) prior to winter so any decomposition between soil and snow doesn't form fungus...
Old 09-02-2015, 04:52 PM   #5
Rewards Points: 145
Here are a couple pictures. Backyard is very lush and green. Entire property is on the shady side as large 100+ year old trees all around the streets.
I believe the grass is Kentucky blue.
Old 09-02-2015, 05:01 PM   #6
Rewards Points: 145
For most of the summer I was picking 30+ mushrooms every morning so I'm thinking the soil is in good shape.
Old 09-02-2015, 05:33 PM   #7
Bluegrass looks dead everywhere this time of year. That is why I have a fescue lawn and even it looks a bit tired.
If you watered that much earlier (mushrooms), don't stop now. Give the grass a chance to put down roots.
Colbyt
The Following User Says Thank You to Colbyt For This Useful Post:
kjmass1 (09-02-2015)
Old 09-02-2015, 06:42 PM   #8
Rewards Points: 145
So in the bottom 2 pictures you think that grass can be revived with water and fertilizer vs reseeding the areas? I'll try and keep up the watering and see what my soil tests come up with over the next couple days.
Old 09-03-2015, 07:19 AM   #9
If the roots lived the grass will revive with cooler temps and a moderate amount of water. Bluegrass is a cool season grass. As such is is always at its best in the spring and fall.
It will spread and fill in naturally if it is allowed to establish roots.
Colbyt
Old 09-03-2015, 05:38 PM   #10
Rewards Points: 862
I'd say hold off on the fertilizer for a few weeks until it cools off for good. Even with watering the grass may go dormant if it gets a lot of direct sun during the day. That's fine and nothing to worry about. When the grass starts greening up again of its own accord, then go ahead with fertilizer - the grass will actually be able to do something with it at that point. If you put it on now you will be basically wasting fertilizer.
The Following 2 Users Say Thank You to Thunder Chicken For This Useful Post:
Colbyt (09-04-2015), kjmass1 (09-03-2015)
Old 09-05-2015, 08:04 AM   #11
Rewards Points: 145
I did a ph test in 2 spots and it looks like it is 7.5, maybe closer to 8. I'm thinking 2 lbs/100sqft would get it down to 6.5-7 for Kentucky bluegrass. So for 1300sqft = 26 lbs. a 20 lb bag should get me started. Any difference in doing this now vs fall vs spring?
Old 09-05-2015, 09:31 AM   #12
Rewards Points: 862
Your enthusiasm is great, but I think you're going a little overboard.
Be careful with kit pH test results - they aren't all that accurate and if you add amendments based on a bad pH reading you can do a lot of harm. If you really want to find out what is going on in your soil, google "UMass soil tesing" - you'll find the UMass Amhest Aggie soil testing lab. You can send them a few samples of soil and they will analyze it for pH, mineral and nutrient content and organics and send you report (costs $20 or so; it's a good service). They'll also provide fertilizer recommendations and tell you what to do to correct any deficiencies, if any. Just do as they recommend and you'll be fine.
Do that, and then just water and wait for cool weather until the results come back.
The Following User Says Thank You to Thunder Chicken For This Useful Post:
kjmass1 (09-05-2015)
Fall with my first lawn. Suggestions with seeding/fertilizer please gargus Landscaping & Lawn Care 0 08-10-2015 11:28 AM
Wasting fall lawn fertilizer in NW rain zone. Hossenfeffer Landscaping & Lawn Care 0 09-26-2013 11:08 AM
Lawn weed killing in the fall? AGWhitehouse Landscaping & Lawn Care 11 08-12-2011 02:19 PM
Newly sodded lawn didnt take in some areas. Over seeding? sandyman720 Landscaping & Lawn Care 14 10-08-2008 04:24 PM
new home, new lawn, fall care ? mahjohn Landscaping & Lawn Care 3 09-06-2008 03:38 PM
