Fireplace HELP Pros/cons - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By lenaitch
Old 10-31-2017, 01:10 PM   #1
Rewards Points: 6
Fireplace HELP pros/cons
We are adding a 20x17 patio addition to our house. I would like to add a "fire" area to our patio. Not sure which version would last longer... traditional stone fireplace or round firepit. I am worried about being outside and water standing in the fireplace.
Please share your opinion and/or experiences
MBwanderlust is offline   Reply With Quote
Old 10-31-2017, 01:47 PM   #2
Rewards Points: 2,242
Re: Fireplace HELP pros/cons
A fire area or pit on a patio sounds risky. Are you thinking gas or wood. if wood those embers can be tossed by the wind.
Check with your insurance company to see what they will accept. Fire is a 4 letter word to them.
Bud
Bud9051 is offline   Reply With Quote
Old 10-31-2017, 08:29 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 1,800
Several things to think about:
Are there any local bylaws/ordinances/rules regarding backyard fires in your locale? Some urban areas outright prohibit them because of smoke. There may also be local building or fire code rules regarding placement and construction methods for the different types.
Metal firepit 'bowls' tend to rust - quickly. I know you can get covers for them but not all are equally effective and, of course, you have to remember to put them on.
Anything that is masonry will be impacted by the regular fire heating plus freezing if you are in that type of area. I'm not a mason and assume there are proper ways to build such things since they have been done for years, but I have seen ones done poorly and they don't last long.
Gas would be easier and less handling of wood, although I realize they're just not the same as wood. Also, the burner, etc. will be subject to the whole rusting thing.
Bud9051 likes this.
lenaitch is offline   Reply With Quote
Old 11-01-2017, 06:24 PM   #4
Rewards Points: 6
Definitely gas fireplace with electric switch. I just worry about water damage over the years
Old 11-01-2017, 06:28 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,054
Ayuh,.... When they rust out, ya buy another 1,.....
Old 11-03-2017, 01:39 PM   #6
Oso954's Avatar
Rewards Points: 1,630
In my area we have a lot more fire pits vs fireplaces. All the well designed pits have drainage built into them.
If I was shopping for a store bought pit, I'd be looking for the drainage system.
Oso954 is offline   Reply With Quote
Tags
fireplace , patio
Trying to troubleshoot a gas fireplace, need help glenh Appliances 3 11-03-2013 06:48 AM
Fireplace reno help, wood to gas fireplace jsunsun Building & Construction 4 01-15-2013 08:09 PM
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 09:56 PM
Fireplace construction question scottyv81 General DIY Discussions 1 01-29-2011 09:26 AM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
