Filling Up Dirt By Raking The Turf/grass Around Foundation Wall - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-13-2015, 11:38 PM   #1
Rewards Points: 6
Filling up dirt by raking the turf/grass around foundation wall
I am planning to fill more dirt around my foundation wall. if i want to remove the grass can i rake it up 3 feet width from foundation wall, put some dirt and again place that grass on the new dirt. Are there any other ideas?.
PVANKINA is offline   Reply With Quote
Old 04-14-2015, 07:50 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,.... It'd probably be easier to rake out the new dirt Over the grass, 'n let it grow through the new dirt,....
Old 04-15-2015, 09:04 PM   #3
Rewards Points: 2,577
I had a similar situation. I could buy rolls of sod or I could just make my own by rolling up the grass that's there. What I did not appreciate is that there is a special machine for cutting sod. If you try to do it by hand, it is agonizingly hard work and you end up with 4 inches of soil stuck in the roots under the grass.
But it does work. Keep the grass cool and moist. Or you could reseed.
mathmonger is offline   Reply With Quote
Foundation Wall Repair/Replace mt999999 Concrete, Stone & Masonry 17 04-14-2014 05:48 AM
Water leaking into basement over foundation wall? Kern1 Concrete, Stone & Masonry 12 10-21-2013 09:37 AM
Replacing sill plate - foundation wall repair NWChris Building & Construction 0 09-14-2013 12:05 PM
sister wall against old stone foundation - bonding agent? tcook555 Concrete, Stone & Masonry 3 03-16-2012 08:23 PM
Retaining Wall Level Foundation sippinjoes Landscaping & Lawn Care 5 04-03-2011 09:01 PM
