Fence Weed Barrier - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By Nealtw
  • 2 Post By mark sr
  • 1 Post By joecaption
Old 06-01-2018, 12:00 PM   #1
Rewards Points: 183
Fence Weed Barrier
Could this work for a chain link fence?
nicksteel is offline   Reply With Quote
Old 06-01-2018, 12:36 PM   #2
Oso954's Avatar
Rewards Points: 1,978
Re: Fence Weed Barrier
Here’s a thread on the same subject.
http://www.diychatroom.com/f16/how-k...needed-379361/
See post #9 for my recommendation.
Oso954 is offline   Reply With Quote
Old 06-01-2018, 12:47 PM   #3
Rewards Points: 183
Thanks.
That is the best way, but my fence is already in and I need to go kinda cheap. I will probably buy a roll (first post) and give that a try in a section of fence for a mow strip.
Old 06-01-2018, 01:16 PM   #4
Oso954's Avatar
Your selected product is designed to reinforce patches. As such, it is covered by other material. That makes me question just how UV resistent it is.
I doubt it will last long.
If I don’t use a proper weed strip, my second choice is a large propane torch. You hit the weeds once to stew them in their own juices which kills them. After a week or so when they are good and dry, you hit them again and burn them out.
Old 06-01-2018, 01:22 PM   #5
retired framer
Rewards Points: 20,488
strips of rolled roofing works good enough.
Oso954 likes this.
Old 06-01-2018, 01:57 PM   #6
Rewards Points: 183
Only eight bucks to try.
Old 06-01-2018, 02:19 PM   #7
retired framer
Saving money is using something that has a chance of working. shingles and rolled roofing as been used for generations as a cheap convenient path or stepping stones type placement around gardens.
Old 06-01-2018, 02:34 PM   #8
Oso954's Avatar
The 25 sq ft of patch material weighs about 1/3 of a lb,
Roll roof material is close to 1 lb per sq ft.
Which one do you think will stay in place better when the wind blows ?
Old 06-01-2018, 02:37 PM   #9
retired painter
Rewards Points: 1,806
I always thought it was easier to just spray weed killer along the bottom the fence a couple times a year.
joecaption and HWU like this.
mark sr is online now   Reply With Quote
Old 06-01-2018, 02:46 PM   #10
retired framer
More and more people getting funny about that stuff. if the fence is shared with a neighbour, could be a problem.
Old 06-01-2018, 04:54 PM   #11
Rewards Points: 17,912
I use nothing but total vegetation killer.
Use this product and it only needs to be done once a year.
https://www.tractorsupply.com/tsc/pr...cide-2-1-2-gal
HWU likes this.
Old 06-13-2018, 10:07 AM   #12
Rewards Points: 183
I have some left over shingles from my house that I'm trying on a section of fence. The are working perfectly around my A/C.
Fence Weed Barrier-img_20180613_095834.jpg   Fence Weed Barrier-img_20180611_191628.jpg
Old 06-13-2018, 10:21 AM   #13
Rewards Points: 1,908
I gave up fighting weeds against the chain link that separates our neighbors from us. I just turn the weedeater sideways and keep a place cleared for the push mower wheel to run in. Hmmm, I need to mow today.
Gregsoldtruck79 is online now   Reply With Quote
T-intersection - fence gets hit constantly Chinagirl Building & Construction 86 09-14-2013 11:38 AM
(Partial) Radiant Barrier Above Finished Attic? Lascaux Insulation 11 09-26-2012 07:56 PM
Cedar Wood Fence - Staining again ddave23 Painting 13 03-22-2012 05:43 AM
DIY Replacement of a Wood Fence rcraftlady Building & Construction 4 03-11-2009 06:03 PM
"T"-ing off of neighbours' fence? curls00 Carpentry 6 01-10-2009 03:39 PM
