Fell Hung Tree - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-13-2014, 12:47 PM   #1
Rewards Points: 52
Fell hung tree
Had a storm flatten the tops of two pines, one of which is still connected to the trunk at 90* (closest trunk in frame). The other trunk since fell, but the top stayed hung at the same point as the other tree crown. I'd normally avoid felling any hung trees, but I'm thinking this one might not be two bad in that it the trunk will either pull the hung crown or it will snap and those branches will swing down and away from the trunk. Am I crazy or is this predictable enough to have a reliable safe zone? Thanks
boogie81 is offline   Reply With Quote
Old 11-13-2014, 01:11 PM   #2
Rewards Points: 107
They are called widow makers for a reason . A hung up tree is highly unpredictable . Personally the only effort I would put in is dialing the phone to a tree service.
jimn01 is offline   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
r0ckstarr (11-13-2014)
Old 11-13-2014, 01:17 PM   #3
Rewards Points: 2,338
Shoot a rope over the mid section and put a snatch block at the base of the tree nearest to vertical from the mid section and pull it down. This will cause it to go mostly straight down.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
oh'mike (11-13-2014)
Old 11-13-2014, 01:23 PM   #4
47_47's Avatar
Rewards Points: 320
I'm with jimn01. The break is too high and unpredictable.
47_47 is offline   Reply With Quote
The Following User Says Thank You to 47_47 For This Useful Post:
Old 11-13-2014, 06:46 PM   #5
Retired Moderator
Rewards Points: 7,174
I agree--dangerous--but--I would do as 'Senior' suggested--shoot a rope over the snag--then pull it out---a truck will do the job--or a come-along----if the rope is long enough,you will be safe.
Old 11-13-2014, 07:16 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,746
Ayuh,.... Agreed, pullin' to the right of where the picture was taken,....
To cut it, I'd kerf it on the same side, to the right of the point of view, cut from away from the camera,....
'n Run like 'ell to the left of the camera at the 1st CRACK heard,....
The Following 2 Users Say Thank You to Bondo For This Useful Post:
chrisn (11-14-2014), oh'mike (11-13-2014)
Old 11-28-2014, 12:28 AM   #7
Rewards Points: 40
Those look dangerous. I would call in some help for this work. It is too risky to do yourself without ample help.
Shell99 is offline   Reply With Quote
Old 11-28-2014, 04:52 AM   #8
Rewards Points: 1,414
Widow-makers are inherently fairly dangerous. Your best option by far is to shift the risk onto someone else by paying someone who does it professionally (and has good insurance) to take it down. They are less likely to injure themselves and should be covered if they do.
If it's a job like that I would tend to find the best tree guy in a rural area or at least a good tree guy if in an urban area--someone who takes them down when they're in tight to a local million dollar home, for example. You pay a premium but your chances of the job going smoothly increase from 60% to 95%.
That said, because this tree is not close to homes, a regular landscaper who has sense and patience will *probably* work too. Just make sure you get proof of insurance and that the guy's not an idiot.
If I had to do it myself I would probably use rope and truck and be sure I was well outside the area it could fall into.
Tom738 is offline   Reply With Quote
Tags
arborist , chainsaw , tree removal
Etiquette Question: Asking Neighbors to Contribute to Tree Removal jlpeifer Landscaping & Lawn Care 14 10-20-2011 05:33 PM
Apple Tree Care bgibson11 Landscaping & Lawn Care 9 05-28-2011 09:28 AM
Extending deck around a tree jcgoldie Building & Construction 2 02-15-2011 06:20 PM
Tree fell on house-broke one rafter rookie1234 General DIY Discussions 2 04-07-2009 02:02 PM
