Featured Paver Wall - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-24-2018, 09:06 PM   #1
Rewards Points: 96
Featured paver wall
Hi guys,
I'm currently working on a paver feature wall for my landscaping and I was wondering if -once it's done- you drop the soil directly against the foundation wall (see photo attached). For me it doesn't make any sens to let the soil directly in contact with the foundation wall. Should I install a geotextile fabric? I've heard people installing a foam against the foundation and then the soil.
Not sure what's best. What do you think I should do?
Looking forward to read your answers.
Cheers.
Martin
martynator is offline   Reply With Quote
Old 10-24-2018, 09:29 PM   #2
Rewards Points: 4,170
Re: Featured paver wall
Yes, you normally put fabric against it so soil does not wash through the wall.
stick\shift is offline   Reply With Quote
Old 10-25-2018, 05:33 PM   #3
Rewards Points: 96
Thanks!
Old 10-26-2018, 01:45 AM   #4
retired framer
Rewards Points: 20,734
Are you talking about the new wall or the foundation of the house.
Nealtw is offline   Reply With Quote
Old 10-26-2018, 05:30 AM   #5
JUSTA MEMBER
Rewards Points: 4,082
Fabric liner, then a weeping tile drain to drain water, then gravel to cover the tile, then a fabric layer covering the gravel, then soil for plantings.
Have the drain tile ( tube), drain away from the area.
This all prevents water from pushing your wall over.
ED
de-nagorg is online now   Reply With Quote
Joining thin wall abs pipe to standard abs pipe Homerepairguy Plumbing 3 03-01-2015 11:39 PM
Can I remove this wall? limited60 Remodeling 9 06-05-2012 01:32 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
