Fastest Growing Grass Seed For Large Area - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By DoomsDave
  • 1 Post By jmon
Old 05-20-2020, 08:42 PM   #1
Rewards Points: 26
Fastest growing grass seed for large area
Need help after my neighbor and I removed some dying bushes between our yards. Whatís the best product to apply when it comes to grass seed in this area for some fast growth!
4rpr is offline   Reply With Quote
Old 05-20-2020, 08:57 PM   #2
Rewards Points: 3,628
Re: Fastest growing grass seed for large area
rye or blue grass are pretty fast growers in the north. You don't mentioned your location. But it should do good no matter location. Tough.
I see lots of pine trees. make sure you rake or vacuum the pine needles/cones regularly and fertilize the soil so the grass has a chance. Pine needles changes the ph level in the soil and can make grass growing in that area harder. Just a suggestion.
jmon is online now   Reply With Quote
Old 05-20-2020, 09:08 PM   #3
DoomsDave's Avatar
Rewards Points: 15,244
@4rpr , @jmon notes that pine needles will make the soil more acid. You can lime it a little bit. The bigger problem usually is live roots on the surface or too much shade.
But, try some rye or blue and see how you do.
Life is one long teaching moment.
DoomsDave is online now   Reply With Quote
Old 05-20-2020, 09:09 PM   #4
Rewards Points: 26
Would EZ Seed -Scottís be worth a shot?
Old 05-20-2020, 09:20 PM   #5
DoomsDave's Avatar
See what kind of seed it is.
Perennial rye, tall fescue, bluegrass okay.
Annual rye, in more than 10% fugeddabouddit.
jmon likes this.
Old 05-20-2020, 09:23 PM   #6
Rewards Points: 7,028
It appears no matter where you're located you'll need a shade tolerant grass. I suspect that'll narrow down your choices considerably.
Old 05-20-2020, 09:47 PM   #7
Rewards Points: 26
Yes it has a mix of those 3. https://www.homedepot.com/p/Scotts-1...7528/204687772
Old 05-21-2020, 07:15 AM   #8
Agree, worth a shot. Anything would be better than that big bare spot you got in the yard.
4rpr likes this.
Old 05-21-2020, 07:16 AM   #9
Rewards Points: 26
When it gets windy is my main concern.
Old 05-21-2020, 07:23 AM   #10
DoomsDave's Avatar
Why is that a problem?
Old 05-21-2020, 07:29 AM   #11
Rewards Points: 11,010
I would plant the same type of seed as the other grass in your yard.
After that, if you are hoping some particular brand is better than others, sorry but I am going to disappoint you.
The seed providers commonly mix in some fast germinating varieties in their bags so they can type in big bold letters on the label "VISIBLE GRASS IN 7 DAYS !!!". Unfortunately, a lot of people (or at least me), think those fast germinating varieties are ugly, or at least don't look good on my lawn.
You didn't state where you are, but May/June is rather late to be planting grass in a lot of places (hence you are looking for fast growing grass, I expect). I would suggest sod -- can't get much faster than that. You will still need to water it for a few weeks until its roots grow in, and by then you are close to July and will need to be attentive to water needs when you get hot, dry stretches of weather.
SPS-1 is online now   Reply With Quote
Old 05-21-2020, 10:27 PM   #12
Rewards Points: 4,840
Annual rye will germinate the fastest and perennial rye just about as fast; bluegrass will be about the slowest germinating of the cool season grasses. Since you haven't listed a location, I'm assuming that's what's appropriate for your area. That said, I would get a soil test and think about tilling the area and really putting in the prep work rather than just throwing some seed.
stick\shift is offline   Reply With Quote
Old 05-22-2020, 07:43 AM   #13
Rewards Points: 26
Problem is the slope where my sump pump hose is. This is close by. When water gushes out, it will take some of the seeds with it. I can reposition the hose or maybe get a different type of hose(so itís not so ugly), but I still need to make sure that water exits the hose and goes down the hill vs getting backed up if I reposition the hose.
Old 05-22-2020, 07:43 AM   #14
Rewards Points: 26
SE WI
Old 05-22-2020, 07:45 AM   #15
Rewards Points: 26
SE WI. Temps here just literally started to get in the 60ís which is essential for seeds to germinate. So although itís May we had no choice to seed before.
