Drywell - Location Of Inlet & Outlet - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-01-2015, 02:26 PM
Rewards Points: 4
Drywell - Location of Inlet & Outlet
Hi - We have a poorly draining back yard (large levels of clay in our soil) and are getting ready to install three trench drains around our patio to improve the drainage. We currently have a 4" PVC drain line that runs from an area drain on one side of our yard to the street where it hooks into the city's storm sewer.
We are planning to tie the three new trench drains into this 4" PVC that runs to the street. We are thinking about installing a dry well to provide a buffer and potentially avoid overloading the line running to the street if we get heavy rains. We would combine the trench drains and run them into the drywell, and have the drywell feed to the 4" PVC that runs to the street.
I had two questions. First, whether the idea of a drywell makes sense. Second, if we use the drywell, can we have the drain lines from the trench drains enter the drywell below the outlet that runs to the street? I'm concerned that if the water level gets above the intlet, then the trench drains may slow or stop draining.
Below is a diagram of what we had in mind for the drywell. Apologize if this is unclear!
Thanks.
lambjere1 is offline
Old 07-01-2015, 03:34 PM
Rewards Points: 5,348
Are you planning one 55 gal drywell? I'd have 2 or 3 daisy chained together. The inlet and outlet pipes at the same level.
Can you get below the clay layer with these drywells. If you can and the layer beneath is sand, the water will perk down into the sand as well as drain to the street in heavy rains.
Ron
B. Franklin 1759
Ron6519 is offline
Old 07-01-2015, 05:47 PM
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,340
Ayuh,.... Use a 6' line to the street, 'n skip the drywells,....
Bondo is offline
Old 07-04-2015, 08:25 AM
Rewards Points: 2,800
The useful maximum water level in a drywell is the level of the input. Higher than that and the inlet is going to back up no matter what else you do.
I would say skip the subterranean French drains around the patio. Use surface runoff via land contour and/or swale to a surface grate over the drywell. Now the level of the inlet is much higher giving you more flexibility over the level of the subterranean outlet.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
AllanJ is offline
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
AFCI and GFCI on same circuit -- 2014 Kitchen Rules Perry401 Electrical 12 10-10-2013 10:09 PM
Plug outlet location in a new school prb_nearnorth Electrical 10 09-14-2011 03:45 PM
New coaxial outlet location shimkc Home Theater 1 01-03-2008 09:55 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
