DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Landscaping & Lawn Care (https://www.diychatroom.com/f16/)
-   -   driving pickup over sprinkler lines? (https://www.diychatroom.com/f16/driving-pickup-over-sprinkler-lines-116953/)
denemante 09-11-2011 08:49 PM
I have an in-ground sprinkler system. I know where all my heads are. We have a huge landscape feature in my front yard, and another in my backyard. Each will take a pickup full of mulch. I want to just back up to either vs. making 55 trips with the wheelbarrow.
Can I drive over the buried sprinkler water lines?
MLMIB 09-11-2011 08:52 PM
how deep are they buried? I would think that it shouldn't be a problem if they're more then 6 inches down but I think the big question is how deep are they.
denemante 09-11-2011 09:02 PM
Sadly, I have no idea how deep they are. It was installed by the previous owner. Didn't come with the house - they hired someone.
picflight 09-11-2011 09:19 PM
Yes, you can drive over them, I have. However, don't park over them.
Gary in WA 09-11-2011 10:50 PM
If worried, find the lines location by "witching" with a 2' length of 12 gauge romex- minus the sheathing, twist them and bend a 6" L-shaped handle. Let the long side hang toward the ground, about 6" up, other short end balanced over two fingers, acts like a magnet, draws toward the line (poly, metal, clay tile, concrete, etc.)up to 10' deep. Finds re-bar in slabs, water lines, electrical wires, conduit, etc. Mark location/direction, cover with a 1/4 sheet of plywood, boards, etc. under tire path. Ground rod wire works even better.
Gary
kmc 09-13-2011 12:17 PM
Make sure the soil is dry and you are fine.
DrHicks 09-13-2011 12:55 PM
That'd make me very nervous, especially considering you don't know how deep they're buried.
The fact that you're doing this in the fall helps. The ground is drier and firmer.
I also like the idea of locating the lines, then putting a piece of plywood over where they are buried.
Good luck!
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
