Drip Irrigation Question - Mixing Flowers/Trees - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-03-2017, 08:21 AM   #1
Rewards Points: 84
Planning some flower beds around areas where I have existing or new trees (all of the existing trees are small and only planted last year - not even close to maturity)
Can I put the trees and the perennial flowers on the same drip line? I know that trees need a good soaking. I am thinking about breaking off a lateral from the main drip line and circling the tree's roots with many emitters for this purpose.
Just double checking before I do any installs. How is this normally done on pro/commercial projects?
Thanks in advance
Scott
bondra76 is offline   Reply With Quote
Old 03-03-2017, 09:59 AM   #2
Rewards Points: 3,438
Re: Drip Irrigation Question - Mixing Flowers/Trees
Trees prefer infrequent, good long deep soakings. If your trees are correct for your climate you shouldn't need to water them at all after they're established.
LawnGuyLandSparky is online now   Reply With Quote
Old 03-04-2017, 06:05 PM   #3
Rewards Points: 84
thanks appreciate it
Old 03-06-2017, 04:48 PM   #4
Rewards Points: 576
Is your main drip line 1/2 inch and your lateral 1/4 inch ? Sounds good....you can put a on-off valve on your 1-4 inch line...so you can shut off water to the trees, when you think necessary.
What are the trees ?
Cedrus is offline   Reply With Quote
Old 03-06-2017, 08:33 PM   #5
Different trees need different types of drip cycles. Depending on the size of the trees and type, you might be able to utilize a drip line for both the trees and garden.
Rocklin Concrete
Brookely is offline   Reply With Quote
Drip Irrigation Help! tinsingh Landscaping & Lawn Care 8 04-01-2013 10:52 PM
Ideas for drip irrigation? funfool Gardening Forum 3 03-31-2013 10:28 AM
Fertilize through drip irrigation? ldb Landscaping & Lawn Care 3 08-02-2012 06:39 AM
Subsurface Drip Irrigation a_lost_shadow Landscaping & Lawn Care 2 03-25-2012 05:32 PM
How do I properly set up a Drip Irrigation system? Telfair Gardening Forum 7 03-25-2012 07:35 AM
