Drainage Terrace - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-24-2018, 03:52 PM   #1
Rewards Points: 4
Drainage Terrace
I've been getting a lot of water from my neighbor's yard for years. Recently I dug a ditch\terrace near the property line. My plan now is to put some kind of gravel in the ditch and then cover it with mulch.
I was wondering if I should use pea gravel, 3/4" gravel or something else?
Also, will covering it with mulch cause problems? If so, are there any other recommendations on what to cover it with?
Thank you
RJM7316 is offline   Reply With Quote
Old 04-24-2018, 05:36 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Re: Drainage Terrace
Ayuh,..... How wide,..??
How deep,..??
How long,..??
How steep is the pitch,..??
Usually bigger rock is better,..... 4" stuff,....
The mulch will rot, leech down, 'n plug the passages through the rocks,.....
Old 05-08-2018, 04:21 PM   #3
Rewards Points: 4
The ditch is probably about 2' wide, 60' long and 14" deep.
Old 05-08-2018, 04:50 PM   #4
retired framer
Rewards Points: 20,734
3/4 crushed works good for drainage and a real heavy fabric under the much will keep it clean.
We have place that have this up to 12 ft wide and will cut it to what you need so as not to buy the whole roll.
https://www.amazon.co.uk/Control-Gro.../dp/B002C09URA
Nealtw is offline   Reply With Quote
Tags
drainage , gravel , mulch , terrace
Washing machine drainage issue Centex2011 Plumbing 6 10-08-2014 03:45 PM
Purchased home, upper tiled terrace deck is leaking we think..how to fix properly tracydr Flooring 0 01-11-2011 03:59 PM
Foundation Drainage bhry Building & Construction 3 09-23-2010 10:08 AM
The IPGC Drainage Pipe agster97 Landscaping & Lawn Care 0 07-09-2009 12:05 AM
Drainage Tile and Retaining Wall nabz Landscaping & Lawn Care 3 05-25-2009 01:22 PM
