Downspout Solutions - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-31-2015, 11:11 AM   #1
Rewards Points: 14
Downspout solutions
Here is the Downspout for my front walkway.
The dirt area will be a small raised garden. I am not really happy with the location of the downspout laying right across the main walkway.
I figure I can dig down and try to connnect to weeping ( integrity of sidewalk? how far down? bottom of foundation would be like 9 feet. doesnt seem doable) or I can go under the sidewalk and do something then. Any ideas. Im located in Edmonton alberta Canada. Also where would I look to find applicible codes and permits required?
thefatpigeon is offline   Reply With Quote
Old 05-31-2015, 11:39 AM   #2
kwikfishron's Avatar
Rewards Points: 370
Downspout on a hinge? you got to be kidding...........That downspout should be running into a 4" schedule 40 pipe that routes under the slab.
Can't really say where it should end up based on that one picture but it needs to be corrected imo.
Better to do it now before landscaping or it will likely never happen.
kwikfishron is online now   Reply With Quote
Old 05-31-2015, 11:57 AM   #3
Rewards Points: 14
where should it go? weeping?
Old 05-31-2015, 06:42 PM   #4
Rewards Points: 91
well, from the pic it looks like you could do a couple of things.
1. You could disconnect the hinged part, run it the rest of the way down and turn it so it dumps on the sidewalk and drains towards the road.
2. You could disconnect the hinged part, run it down to 3" or 4" PVC and run it under your sidewalk and your yard out to the street (comes out at curb).
3. You could run it down to weeping tile but that is going to be tiresome or costly. You are going to have to dig down pretty far to reach your weeping tile...
nvycrmn is offline   Reply With Quote
Old 05-31-2015, 06:47 PM   #5
Rewards Points: 1,566
I'd move it to the corner and run it onto the drive.
Old 06-02-2015, 08:03 AM   #6
Rewards Points: 297
This is the easiest solution. Just relocate the downspout to the portion of the gutter near the garage door, and have is discharge down the driveway. Heck, you could probably just add an elbow where the "hinged" joint is now, and run it towards the front of the house, discharging onto the sidewalk.
I guess maybe in Canada discharging across a walkway is bad news because of concerns about icing? In that case I'd do the same thing but run 3" pvc under the sidewalk and discharge into the yard. You can tunnel under the sidewalk fairly quickly with something like this:
http://www.homedepot.com/p/Orbit-Wal...3333/100127846
red92s is offline   Reply With Quote
Need help with extending my downspout underground... DIYguy2000 Landscaping & Lawn Care 1 09-11-2014 01:25 PM
Downspout on sidewalk in front of the house nohandyman2014 General DIY Discussions 8 06-27-2014 08:26 PM
Should I add a downspout? scottyv81 Roofing/Siding 5 05-09-2012 07:37 PM
Water Overflow from Downspout Drain Nospammer Building & Construction 1 10-04-2011 04:18 PM
Replacing patio - Relocate downspout slvrbullet98 Landscaping & Lawn Care 2 05-08-2009 08:30 AM
