Downspout Drainage Issue - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-18-2019, 10:02 AM   #1
Rewards Points: 16
Downspout drainage issue
Good morning. I have a drainage issue in my back yard causing some serious erosion problems. It is caused by the gutter downspouts at the corner of the house - one spout on the back and one on the side of the house. However they are side-by-side (attached) - 9" apart (outside dimensions). I thought about just attaching the downspouts to some 4" corrugated and run them out to a popup. However that corner of the house has some trees that clog the downspouts and sometimes the water runs over the edge of the gutter, causing more erosion. So the popup would get clogged. Other options? Any advice would be great. Thanks.
Scott
freebird_wr is offline   Reply With Quote
Old 02-18-2019, 01:32 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Re: Downspout drainage issue
Other options?
Ayuh,.... What I would do, is,.....
Dig a swale/ trench from the spouts, down 'bout a foot, out to where it'll daylight drain,....
'bout 1' wide at the bottom, 'bout 3' wide at the top,....
Lay a 2' wide strip of fabric down the middle, then fill the trench/ swale with 2" washed stone,.....
The 2" stone is big enough to drain quickly, but is still "Walkable",....
Old 02-18-2019, 01:36 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,642
Turn the splash blocks around to begin with.
Next...if you have enough water, you are going to have erosion.
How is grade away from the home?
Old 02-18-2019, 01:49 PM   #4
Hammered Thumb
Rewards Points: 2,064
Sounds like a plan. Just use sewer pipe (grey one) instead to not catch debris.
Gutter guards or periodic cleaning. If you slope the drain properly, any debris will accumulate at the end. Take the pop-up cap off and remove junk. Everything requires maintenance.
On heavy rains, the flow shoots off the cap and clears the pipe naturally.
3onthetree is offline   Reply With Quote
Old 02-18-2019, 02:03 PM   #5
Rewards Points: 16
I had the splash block correct but with 2 golden retrievers in the backyard, it gets moved quite a bit.
I was worried about the trash in it, but if the pop ups can come off then I think that would be the route to go.
Thanks all for your responses.
Old 02-18-2019, 02:21 PM   #6
retired framer
Rewards Points: 20,612
Pop ups would not be good where you have freezing.
Do not use flat bottom gables with scissor trusses.
Old 02-18-2019, 02:56 PM   #7
Rewards Points: 16
We are in middle Georgia so I don’t think freezing is too much of an issue.
Crawlspace drainage issue grubbah General DIY Discussions 4 07-08-2014 10:51 AM
Need help with drainage from downspout asbury park Landscaping & Lawn Care 7 07-14-2012 07:23 PM
Another drainage issue Ranger1227 Landscaping & Lawn Care 6 05-23-2011 12:57 PM
drainage issue jeremiah1 Building & Construction 4 12-14-2009 07:32 PM
Drainage issue and need suggestion on type of grass golfer2b Landscaping & Lawn Care 9 03-24-2008 07:38 PM
