Does Anyone Know What This Is? (photo Attached) - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree10Likes
Old 04-25-2017, 04:57 PM   #16
paper hanger and painter
chrisn's Avatar
Rewards Points: 34
Re: Does anyone know what this is? (photo attached)
I still bet on an old stump
Old 04-27-2017, 11:49 AM   #17
HandygalTX's Avatar
Rewards Points: 14
Doesn't grub worm work from the inside out and make the ring bigger every year? Did on a patch of St. Augustine in TX.
HandygalTX is offline   Reply With Quote
Old 04-27-2017, 11:59 AM   #18
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,274
Originally Posted by Yodaman View Post
Any previous Colts fans at this address?
Originally Posted by jlhaslip View Post
Around here it is called Fairy Ring.
http://www.salisburygreenhouse.com/f...her-mushrooms/
Any previous fairys at this address????
MTN REMODEL LLC is offline   Reply With Quote
Old 04-28-2017, 07:13 AM   #19
Rewards Points: 4
Is it in the area of sonething reflective? Maybe the sun is bouncing off a window or car?
Sent from my SM-G950U using Tapatalk
tommyrhodes is offline   Reply With Quote
Old 04-28-2017, 07:24 PM   #20
Rewards Points: 28
It's fairy ring and necrotic spot. The darker circle part at top of picture is fairy ring, the dead part is necrotic ring spot. Caused by not properly removing a stump. Most people will grind the stump and just rake it out and seed. The wood chips or debris will then break down and tie up nitrogen (Carbon:Nitrogen ratio gets out of whack). Dig it out and replace with fresh soil and reseed or sod, you'll need to go down probably 6" at a minimum.
123pugsy likes this.
acrossturf is offline   Reply With Quote
Old 04-29-2017, 02:58 AM   #21
chrisn's Avatar
Rewards Points: 34
Just what I have been saying. Sort of.
Old 04-29-2017, 07:33 AM   #22
Rewards Points: 30
They're all wrong. It's a necrotic ring spot. It's due to a fungus. Not a big deal.
jstaubin is offline   Reply With Quote
Old 04-29-2017, 12:43 PM   #23
Rewards Points: 22
It does look like necrotic ring spot. You can use fungicide as a temporary treatment but likely you will have to dig up the area and put new soil and seed down.
G'terDone is offline   Reply With Quote
Old 04-29-2017, 01:02 PM   #24
Rewards Points: 4,362
This seems like a great video, with both tips on diagnosis & problems with over watering ( like rain!)
Nik333 is online now   Reply With Quote
Old 04-30-2017, 09:06 AM   #25
Rewards Points: 30
It is a late stage necrotic ring caused by a fungus.
Trim attached to recessed lighting can, want to retrofit chamsalife18 Electrical 12 04-22-2016 09:58 AM
Attached Garage Ceiling Code? eagle107 Building & Construction 17 11-14-2015 09:44 AM
Subpanel in attached garage/workshop question RockyMtnBlue Electrical 9 09-27-2014 06:30 PM
What is this called? (Photo attached) JoeyJoeJo Building & Construction 14 05-18-2011 02:20 PM
Proper venting of new roof on attached garage jlatulippe Roofing/Siding 1 11-26-2009 03:24 PM
