Do I Need A Drainage Tile Along This Wall & House? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Windows on Wash
  • 1 Post By Nealtw
Old 10-03-2017, 09:35 AM   #1
Rewards Points: 204
Do I need a drainage tile along this wall & house?
I put in the short (max 3') but long (22') along my house. See pictures (if you click on them it rotates them properly). Since installing, I've been getting a small amount of water in my basement during heavy rains. I'm wondering a couple things:
1) should I still a perforated drainage pipe along the wall and side of the house?
2) would better dirt grading (more aggressive) solve the problem?
3) when I dig down along the house foundation, I noticed gaps in block which are intentionally there. Should I fill with concrete?
Do I need a drainage tile along this wall & house?-img_3258.jpg   Do I need a drainage tile along this wall & house?-img_3257.jpg
arminius is offline   Reply With Quote
Old 10-03-2017, 01:01 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,642
Re: Do I need a drainage tile along this wall & house?
Unless you are going to dig down the footer and waterproof the wall, putting in perforated pipe near the soil level will do next to nothing.
Proper grading and gutter routing will help more than a pipe near the soil surface.
47_47 likes this.
The Following User Says Thank You to Windows on Wash For This Useful Post:
arminius (10-03-2017)
Old 10-03-2017, 01:07 PM   #3
retired framer
Rewards Points: 20,634
We would like to see about 6" of concrete below the siding. What you have now will allow bugs to climb in. Correcting the water flow up top may fix the problem before you start digging for drain pipe.
As pointed out it would want to be just below the floor level.
47_47 likes this.
The Following User Says Thank You to Nealtw For This Useful Post:
Tags
drainage , retaining wall , wet basement
Need Some Advice About A House With An Issue neutropia General DIY Discussions 7 01-29-2017 06:46 AM
Replacing retaining wall in front of old wall - options? dc300m01 Landscaping & Lawn Care 2 07-04-2016 09:43 PM
Extend wall or cut tile? wraiththe Plumbing 19 12-07-2011 07:50 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 03:29 PM
