Do I Need Conduit - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-12-2016, 12:33 PM   #1
WonderHorse's Avatar
Rewards Points: 2
Do I need conduit
I have a new landscape lighting project. These are low-voltage LED lights. Do I need to run all the wire in conduit?
WonderHorse is offline   Reply With Quote
Old 03-12-2016, 12:57 PM   #2
Oso954's Avatar
Rewards Points: 1,974
Re: Do I need conduit
Typically, you use low voltage landscape wire which is direct burial rated. The only conduit used would be for going under cement(eg sidewalk).
http://www.homedepot.com/b/Electrica...e/N-5yc1vZc57l
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
WonderHorse (03-12-2016)
Old 03-21-2016, 04:07 AM   #3
Rewards Points: 8
I recently embarked on a landscape lighting project and ended up going HOG WILD!!!! Now, I've got nearly 2.5 acres with a lot of large trees I wanted to uplight and did get two bids from "pros" although here in WI, we don't need ANY type of license for low voltage, which is good for me and DIY, but also means nearly ANYONE can get into that business.
I ended up DIY'ing it and was lucky enough to get some GREAT advice from several out of state pros, who judging from their websites, they were true pros.
All said the same thing-PIPE IT!!!!! Yes, proper landscape wire in direct burial rated, but its 100x better off fully protected in pipe. Also, if you go with any of the store brands, cut off those STUPID wire pinching connectors (why poke holes in elec wire insulation???) and you'll get far more years of use out of it!!
RTunlim is offline   Reply With Quote
Old 03-21-2016, 11:55 AM   #4
Rewards Points: 459
I had some buried Low-V cable get chewed up by a woodchuck last year. I suggest conduit.
Nick DIY is offline   Reply With Quote
EMT Conduit Size [email protected] Electrical 25 09-24-2014 11:03 PM
Long run of conduit for underwater pool light/switch BrandonC_1972 Electrical 1 06-25-2014 05:54 AM
PVC conduit questions powertoolguy Electrical 4 08-28-2013 06:30 AM
Using 2" PVC electrical conduit RonLNY Electrical 7 01-06-2013 10:34 PM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
