Do All Chainsaws Leak Chain Oil While In Storage? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-03-2015, 10:43 AM   #1
Rewards Points: 314
do all chainsaws leak chain oil while in storage?
I sold my problematic Craftsman 16" chainsaw a few years ago and replaced it with a Stihl 16" MS250 which has sweet cutting action. However I noticed every time I open the case (every few months whenever I need it) there is chain oil in the bottom of the case and the chain oil reservoir is half empty. Is this normal? It's not like I store the case in an unconventional position.
njitgrad is offline   Reply With Quote
Old 06-03-2015, 12:06 PM   #2
A Little Of Everything
Rewards Points: 1,420
Mine leak like that.
DrHicks is offline   Reply With Quote
Old 06-03-2015, 12:11 PM   #3
Rewards Points: 3,664
That's how they can advertise - AUTOMATIC OILER - and charge more
SeniorSitizen is offline   Reply With Quote
Old 06-03-2015, 12:47 PM   #4
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,530
Yep. My Stihl leks.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 06-03-2015, 02:41 PM   #5
Civil Engineer
Rewards Points: 5,246
I have a Stihl Farm Boss, it has not leaked oil in three years. My old Poulan used to leak oil. My old Husqvarna did not leak oil. So there are at least two chain saws in the history of the millions of chain saws out there that did not leak oil.
Old 06-03-2015, 02:51 PM   #6
Rewards Points: 314
Well you gotta figure that whatever is left on the chain eventually drips down and collects in the bottom of the case because the bottom of the case is smooth. Unless of course you wipe your chain dry each time. But who in their right mind would do that? I just sop up the oil every time I open the case with paper towels and add more bar lubricant to the reservoir before using it.
Old 06-03-2015, 05:26 PM   #7
123pugsy's Avatar
I found a stainless steel tray under my old washing machine and I just set it in that every time I finish with it.
Old 06-03-2015, 07:31 PM   #8
Rewards Points: 26
when the motor runs it builds pressure in ur cutting oil tank. That's what pushes the oil out onto the blade. When you shut down ur saw the pressure is still in the tank. So the oil keeps on dripping. Open the lid to the tank and this releases the pressure. And The drip stops.
I was frustrated for years till someone pointed it out to me. Same saw. No more puddle.
Oden is offline   Reply With Quote
The Following 6 Users Say Thank You to Oden For This Useful Post:
123pugsy (06-06-2015), 47_47 (06-04-2015), del schisler (06-04-2015), jmon (06-06-2015), njitgrad (06-06-2015), oh'mike (06-03-2015)
Old 06-03-2015, 10:58 PM   #9
Rewards Points: 996
i also have a Stihl Farm Boss ms290 18'. the dealer told me to use the plastic tool in the kit to rotate the chain a few times to relieve the pressure. i have a tiny bit of oil in the case, but really no isssue.
Fix'n it is offline   Reply With Quote
Old 06-04-2015, 10:15 PM   #10
Rewards Points: 1,674
My ms290 Stihl does not "leak" oil...but as noted there is oil on the chain that drips down. Mine sits on a plywood shelf and has for a ten plus years and there are small oil stains on the ply....but no puddles. If you are getting good sized puddles in the case, you have a problem...perhaps bad seal on the oil tank. Ron
ront02769 is online now   Reply With Quote
Old 06-06-2015, 08:21 AM   #11
Rewards Points: 314
Sounds logical. I will give this a shot.
Garage door chain hopped off--how to fix (w/o adjustable slack)? EricBNeverScare Windows and Doors 5 07-10-2013 10:20 AM
Toilet leak continues after replacing parts Oldern Plumbing 0 03-29-2012 11:15 AM
Possible small gas leak in black iron pipes WillK Plumbing 4 01-18-2012 12:07 AM
leak in cement tile roof virgo822 Roofing/Siding 2 07-23-2011 06:29 AM
attic storage storageseeker Building & Construction 2 01-29-2009 09:02 AM
