DIY Kick Type Sod Cutter? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-28-2015, 08:59 PM   #1
Rewards Points: 452
DIY kick type sod cutter?
Those kick type sod cutters are expensive at $300.
Renting a motorized sod cutter isn't cheap either, and I don't have a truck to haul it.
I was wondering if a kicked sod cutter could be made with lumber, some steel plumbing pipe, and 1/8" thick steel.
Do you think this would work?
Looking to make a one-time sod removal task easier.
pman6 is offline   Reply With Quote
Old 06-28-2015, 09:24 PM   #2
Msradell's Avatar
Rewards Points: 824
For most types of grasses it takes an awful lot of force to cut the sod. If you look at how the commercially made manual cutters are constructed they are extremely strong to take the required forces. I don't even see a roller in your design and the roller is definitely required to control the depth you are cutting the sod at, it needs to be consistent.
If the sod is worth saving it's worth doing right or else side is going to just plain die anyway. Best bet would be to rent one of the power sod cutters.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 07-01-2015, 07:53 AM   #3
Rewards Points: 88
How big is the area of grass you need to remove?
thediyhubby is offline   Reply With Quote
Old 07-01-2015, 08:40 AM   #4
Rewards Points: 474
I have cut a lot of soil over the years and if you do not have good sandy soil forget it
BrowneBearLLC is offline   Reply With Quote
Tile snap cutter ponch37300 Flooring 3 06-29-2015 03:00 PM
Masonite type stucco siding Cmeller Carpentry 3 03-28-2011 10:15 PM
Circuit breaker Type Q vs QP orange Electrical 6 12-15-2010 03:35 PM
Worst tile cutter ever vs. Best tile cutter ever ManMythLegend Flooring 4 01-23-2010 01:27 PM
Tile Cutter vs. Tile Saw jamiedolan Flooring 8 11-09-2008 03:17 AM
