Digging Trench In Soggy Yard - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-20-2015, 11:05 AM   #1
Rewards Points: 68
Digging trench in soggy yard
I have decided French drains leading into a sump pump is my only option for getting my yard usable (currently always soggy after a rain; cant even mow it until a week or so after rainfall). I am concerned that when I start digging my trench it will just fill up with water. Should I just wait until is hasn't rained for a week or so and try it then? Will it be possible to create the trench I need even if its fills with water while I am trying to fix the problem? Maybe I should have the sump pump hooked up and draining the water out while I dig? Any tips are appreciated.
jabrock1 is offline   Reply With Quote
Old 04-20-2015, 02:42 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,.... I ain't gonna say it can't be done, but it ain't easy workin' in a trench full of water,....
A trashpump might keep up with it as ya go,...
Yer problem needs to be fixed with surface gradin',....
Old 04-20-2015, 02:56 PM   #3
Rewards Points: 68
If I could solve via regrade I would but I have neighboring fences on all sides and my current grade it at or below street level. I don't know what else to do besides a sump pump.
Old 04-20-2015, 03:01 PM   #4
Rewards Points: 68
This is what I am dealing with after a heavy rain fall. It stays wet for quite a while after.
Old 04-20-2015, 03:16 PM   #5
Bondo's Avatar
Ayuh,.... I tried in yer other thread, but confusion set in,....
In there, at yer back fence, in yer overhead pictures, does the water flow From behind the fence, into yer yard,..??
If it's yer neighbor's water, comin' in, the Fix starts over there,...
Yer blue arrows say the water flows away from yer side of the fence to the other side,...
If it wants to flow under the fence away from you, cut the bottom of the fence off,...
Old 04-20-2015, 08:35 PM   #6
firehawkmph's Avatar
Rewards Points: 2,464
Bondo,
My yard is larger, but fairly flat, just a slight pitch towards the street. I installed French drains down both sides of the yard. In my case, I had a trencher that dug a 6" slot. I was able to go about 12" deep. I used 4" perforated schedule 35 PVC pipe and laid it in the trench. Covered with #57 limestone to grade. Raked out the dirt that came out of the hole about 1/2" deep over the gravel and through some grass seed on it. Grass grew, water drains, no problem cutting grass the next day. I used to have standing water for a week after a good rain. I have a shallow drainage ditch next to the street that my pipes dump into. You could run yours just deep enough to bury the pipe and cover with an inch of gravel, as long as the water has somewhere to exit the pipe. If you go to dig, wait for dry weather or you'll have a mess. I did mine in July when it's dry and hot up here in Ohio.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 04-21-2015, 07:01 AM   #7
Rewards Points: 68
Originally Posted by firehawkmph View Post
Bondo,
Mike Hawkins
My issue with that is if I start my trench towards the back of the house and dig down 8" for example, by the time I get my pipe to the street, with a slight downward slop in the trench, I will be well below street level. Does a French drain have to lead to daylight?
Old 04-21-2015, 08:13 AM   #8
Bondo's Avatar
Ayuh,... Have any grades been shot with a laser level,..??
Old 04-21-2015, 08:36 AM   #9
Rewards Points: 68
I measured best I could with a line/ line level. Had a couple inches of drop from the back corner of the house to the street. approx. 3" over about 75 feet. Got a guy coming this week to take a look at it. Hopefully he can shoot it with a laser level.
Old 04-21-2015, 09:48 AM   #10
Bondo's Avatar
Ayuh,.... With the tiny margins yer workin' with, a string level ain't accurate enough, by a mile,...
Ya need to shoot it with a laser level, 'n story pole, or a low tech sight level, 'n story pole,...
Old 04-21-2015, 09:50 AM   #11
Bondo's Avatar
'n ya still haven't said whether the water at the back fence is Comin' from the neighbor's, or goin' to the neighbor's,.....
Now ya got 2 threads 'bout the same topic, 'n I'm postin' in the wrong one,....
Old 04-21-2015, 10:19 AM   #12
Rewards Points: 68
Haha my bad! Lets just carry on in the other thread
Worst Back Yard ever...HELP! Cycule Landscaping & Lawn Care 2 09-04-2014 01:45 PM
Digging up large yard Budfudder Landscaping & Lawn Care 4 09-02-2014 07:22 PM
Something is digging in my yard at night SingleGuy Landscaping & Lawn Care 6 03-23-2012 06:49 PM
Back yard redo - Weeds out of control carquote Landscaping & Lawn Care 6 03-03-2012 08:24 PM
digging a trench for electrical...direction? Dusty Electrical 5 10-16-2006 02:44 PM
