Digging Hole For Pond In Backyard - Landscaping & Lawn Care - Page 4 - DIY Chatroom Home Improvement Forum
Old 06-23-2015, 06:51 AM   #46
Rewards Points: 6,997
QUOTE=drelldrell;2184666]
On a side note - can you let me know what type of heated ring you use?[/QUOTE]
Very nice job!
A 6" plastic ball works for free and well until it gets really cold.
Since I'm sure it does in your area. I use this when I absolutely have to http://www.tractorsupply.com/en/stor...icer-1250-watt and no exposed elements. Fortunately I never have to use for more than a few days at a time. There may be less consumptive options.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 06-23-2015, 07:19 AM   #47
47_47's Avatar
Rewards Points: 320
Temperature / location plays a big part. All you need is to keep an air hole open. As Colby stated the ball method works for him, I tried it and doesn't work effectively for me.
47_47 is offline   Reply With Quote
Old 06-28-2015, 12:41 PM   #48
Rewards Points: 2,800
You may need to put in a liner or a waterproof bottom to keep from losing the water into the ground and having to replenish (metered) from the tap.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Cutting Hole for Bathroom exhaust jburchill Kitchen & Bath Remodeling 14 04-16-2012 11:55 AM
patching hole in 8" concrete block BlueBSH Building & Construction 5 08-09-2011 06:55 PM
Need to enlarge hole in wood top plate: or use flex with minimum OD. mysterylectric Electrical 3 08-09-2011 02:52 PM
Sump hole and water drain questions Ncasalejr Plumbing 1 06-21-2011 09:57 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
