Digging Critters - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-17-2018, 06:07 PM   #1
HDS
Rewards Points: 318
Digging critters
Found these two holes in my yard, they are 2 inches in diameter, one is 12 inches deep and the other is 16 inches deep, basically straight down.
We do have squirrels a plenty and lots of small holes in the yard. The yard is also quite bumpy too. The squirrels and birds have been picking at the yard a lot so figured grubs. Was going to treat for the grubs with a granual insecticide.
Also have noticed some chipmonks and we do have a skunk that lives somewhere near by.
There doesn't seem to be any tunnels to indicate moles, so not sure what else it could be.
Sent from my SM-G950U using Tapatalk
HDS is offline   Reply With Quote
Old 10-17-2018, 06:49 PM   #2
Guapo
Rewards Points: 11,950
Re: Digging critters
Does it really bother you or is it causing other problems? What would you like to see happen?
Guap0_ is offline   Reply With Quote
Old 10-17-2018, 06:50 PM   #3
Rewards Points: 6
Why does it matter? afraid of turning ankle?
matt100500 is offline   Reply With Quote
Old 10-17-2018, 07:13 PM   #4
HDS
Rewards Points: 318
With the lawn as bumpy as it is, turning an ankle is possible. The kids also fall when running too.
Old 10-17-2018, 07:15 PM   #5
HDS
Rewards Points: 318
The other issue is you can really feel the bumps when mowing. The riding mower wasn't an issue, but now using a walk behind push mower it is rough going.
Old 10-18-2018, 12:20 AM   #6
Rewards Points: 1,144
Yes, squirrels do a fine job of screwing up a yard. They dig around for nuts. If you have big mature trees, they will terrorize the yard.
I have a custom built whisper rifle that I use frequently to "solve problems". Works great!
viper is offline   Reply With Quote
Old 10-18-2018, 07:50 AM   #7
retired painter
Rewards Points: 656
Skunks will also dig for food.
Depending on where you live, viper's solution is probably the most effective.
mark sr is online now   Reply With Quote
Old 10-18-2018, 08:24 AM   #8
Retired Handyman/Painter
Johnny_inFL's Avatar
Rewards Points: 1,258
run-of-the-mill MOLES
Johnny_inFL is offline   Reply With Quote
Old 10-18-2018, 08:13 PM   #9
Rewards Points: 1,816
You said there are no tunnels so you don't think you have moles, yet you also say the lawn is lumpy.
I'll go with moles as well. I have moles, have had for a couple of years now, and I find those strange holes at times. My theory is that they are some kind of air circulation holes.
We tend to not see the tunnels in the dead of Summer, because when the weather is hot moles work deeper. Now that Summer has ended here, I am seeing the tunnels again, because they are digging much more shallow. Long term, the tunnels collapse and you end up with lumpy lawn.
ChuckF. is offline   Reply With Quote
Old 10-19-2018, 11:51 AM   #10
Rewards Points: 584
12 and 16 inches deep, straight down ? Strange. Find a long screwdriver or thin piece of rebar and start polking and following the bumps. What do you find ?
Cedrus is offline   Reply With Quote
Old 10-19-2018, 12:34 PM   #11
I know moles and gophers well. Was taught very young how to kill gophers but moles are certainly different. Moles will have a dwelling tunnel network and a feeding network. Feeding tunnels are the surface tunnels, but they do bore deep tunnels for living. I have killing no less than 100 of them. The best way imo is a lawn chair and a 12 pack (no a 6 pack won't do). You walk in all the surface tunnels you can find and determine where they are active. Then simply watch for them. Look like a mouse under the carpet and you can actually hear them breaking roots off. Once you see one, use a SHOVEL to pop the plug out where they are and chop them. Believe it or not, you can miss with a screwdriver but if you do use that method, use a straight blade. It will go through them, then hang up inside them and usually pull them out of the ground. I have missed before. The shovel never misses.
They can get back in the ground extremely quick so as soon as you see their worthless furry ass, kill em. They like to find the edge of something and follow it. Sidewalks, houses, etc.
Gophers will leave a mound and are very seismic sensitive so you won't sneak up on them. I use an old shcool piercing trap. You don't have them so I won't go into that.
Old 10-19-2018, 08:46 PM   #12
Rewards Points: 584
If they are moles....per the above, put a square shovel behind the moving mound and another ahead of the moving mound. Now dig down and remove said mole and transport to your Mother-In-Laws yard.
Digging Hole for Pond in Backyard drelldrell Landscaping & Lawn Care 47 06-28-2015 01:41 PM
Replacing two existing 2' retaining wall, options for digging? BT5150 Concrete, Stone & Masonry 10 11-06-2014 06:58 PM
holding back gravel, trench digging mmason2014 Plumbing 3 10-31-2014 05:47 PM
Flex Duct and critters lakeresident HVAC 10 11-18-2011 08:01 PM
Digging basement to add headroom space LU'S BASEMENT Building & Construction 20 05-19-2010 09:01 AM
