DG Path - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By ron45
Old 01-27-2018, 10:38 AM   #1
Rewards Points: 516
DG path
I've been working on a short path with a low grade in my backyard. One day a week for an hour. So far I have the bender board frame, weed barrier and 2 inches of base rock installed.
I had to relocate a drainage box and extend/replace a section of the drainage pipe.
Now that it's rained the section over the drainage pipe gets squishy.
I was planning on getting the DG today but now I feel like I should dig that section up to fix the mud puddle.
Should I put drainage sand and gravel in the pipe trench? Should I redo the pipe and it's connections? Or will everything compact well enough over time?
Arrow3030 is offline   Reply With Quote
Old 01-27-2018, 11:59 AM   #2
Rewards Points: 516
Not sure if this picture is loading properly
Old 01-27-2018, 12:22 PM   #3
dd57chevy's Avatar
Rewards Points: 2,732
Re: DG path
OK , I'll show my ignorance .....what's a DG ?
dd57chevy is offline   Reply With Quote
Old 01-27-2018, 12:43 PM   #4
Rewards Points: 516
Decomposed granite.
Old 01-28-2018, 09:14 PM   #5
Rewards Points: 4,434
Re: DG path
I thought it meant dog path.
Otto W likes this.
ron45 is offline   Reply With Quote
Old 01-28-2018, 10:25 PM   #6
retired framer
Rewards Points: 20,734
Re: DG path
I hope the pipe has holes to pick up water and I would want it all to be gravel instead of mud.
Nealtw is offline   Reply With Quote
Neutral path between two main panels EMiller Electrical 13 03-17-2014 07:48 PM
Metal Conduit Ground Return Path code yogidog Electrical 16 03-05-2014 07:44 AM
Flagstone Path - How to Fix Unstable Stones jbk Landscaping & Lawn Care 2 10-29-2010 04:59 PM
curved wooden path funathome Carpentry 1 10-03-2010 04:00 PM
