DeezTrees: Dead Or Alive? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 3 Post By de-nagorg
  • 1 Post By DoomsDave
Old 08-06-2018, 12:35 AM   #1
Rewards Points: 4
Question
DeezTrees: Dead or Alive?
Hey everyone,
This is the current situation of the two trees in the front yard. They weren't in good shape when I moved in 8 months ago. I've been watering them regularly.
What should I do to save them?
Any suggestions would be appreciated.
Cheers!
DeezTrees: Dead or Alive?-tree-1.jpg   DeezTrees: Dead or Alive?-tree-2.jpg
Last edited by botanyman; 08-06-2018 at 12:43 AM. Reason: Pictures needed to be rotated
botanyman is offline   Reply With Quote
Old 08-06-2018, 04:37 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,328
Re: DeezTrees: Dead or Alive?
Unless you are in an arid climate, normal rainfall will take care of trees. Your location is not specified in your profile. This winter, trim 1/3 of all the limbs, trying to cut all the scraggly ones you see now. That will give the new growth a way to produce.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 08-06-2018, 04:51 AM   #3
Rewards Points: 4
Sorry about that, I didn't realize. I'm in Houston, TX.
Thanks for the reply!
Old 08-06-2018, 06:49 AM   #4
Rewards Points: 2,004
Not an arborist here. Do a close inspection for insects or worms on the trees. Break one of the bare limbs and see if it is dry and brittle or does it still has flexibility and soft inner core ? If dry and brittle the trees may be goners. If still greenish with live cores, may be just an attack of insects or leaf disease etc.
Only an arborists could tell from here, maybe one from your local State Agriculture Extension office ?. The arborist I called at our AE office came out and gave our black cherry tree that is 60 ft. tall, the death diagnosis.
He just looked at the dying limbs and stuck a scratch awl in the tree a inch deep easily and said, Yep, she is a goner, there may be 5- 10 years or more left in her, before she needs cut down or falls down from a storm."
Gregsoldtruck79 is offline   Reply With Quote
Old 12-06-2018, 09:23 AM   #5
DoomsDave's Avatar
Rewards Points: 5,726
Originally Posted by botanyman View Post
Hey everyone,
Cheers!
Give a closeup picture of the trees' leaves, etc., maybe with your hand in the picture for scale. What they are will help determine what you need to do.
I ran a garden shop a long while back, and people often plant things from home when they move far from it, with bad results for the plants.
If you've solved your problem, share the solution with the rest of us.
DoomsDave is online now   Reply With Quote
Old 12-06-2018, 09:56 AM   #6
Rewards Points: 1,598
Once again location does nothing but satisfy inquiring minds.
Old 12-06-2018, 10:48 AM   #7
JUSTA MEMBER
Rewards Points: 4,106
Here is an anecdote for you.
I bought and moved into a home, that had a beautiful honey locust sapling planted in the front yard, watered and tended it for three years, but it died anyway, so I went to dig it up and replace it.
I found that the danged realtor had placed that tree as a ruse, they did not even take the bag off the poor thing and give it a chance, it died from having no space to grow into.
Your trees look to be having similar difficulties.
Before they die, dig around the base, to see if the bag is still around the root ball, and if it is, get it out of the way, let the trees have a chance to grow.
ED
chrisn, Dave Sal and DoomsDave like this.
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
DoomsDave (12-06-2018)
Old 12-18-2018, 11:04 AM   #8
DoomsDave's Avatar
In gardening, as in real estate, it's location
Location,
AND
location.
A solution for Arizona might bomb entirely in the Louisiana bayou. Or Cleveland, or triple vice versa.
de-nagorg likes this.
No power to light switches and outlet Deco Electrical 6 09-12-2017 01:13 PM
Direction of dead bolt locks miamicuse Windows and Doors 6 04-19-2014 02:01 PM
Dead circuit, couldn't find problem so tied into second circuit zappy12 Electrical 25 12-13-2012 09:38 PM
