Deck Post Removal - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-08-2015, 02:50 AM   #1
l008com's Avatar
Rewards Points: 620
Send a message via AIM to l008com
Deck Post Removal
I could explain what I'm trying to do, but this picture sums it up perfectly:
http://i.imgur.com/FWeMY4w.jpg
These aren't deck posts, they are from a handicapped ramp from the previous home owner. Nearly all of the cement footings are in holes cut through the driveway or walkway around back. So digging isn't really an option. Plus I'd like to not do any more damage to the driveway. Some day I'll get a new one, but probably not any time soon. As you can see in the photo, only one post is fully freed from structure at this point. And I am able to wiggle it around quite a bit. So I've googled around at various fence post pullers, some seemed like they might work. Others not so much. My favorite was a little A frame this guy welded up that let him pull posts straight up using a tow strap on his truck. That would be my preferred method. But Im' not going nuts here. This is a one time deal and there's only so many posts I need to remove. I've looked at the local tool rental place (sunbelt) but they don't seem to have anything that would help.
Part 2:
Once I get the posts cleanly out of the holes, what's the best way to fill the holes?
If they were in the dirt, i'd just fill em, tamp em, top them off if they settled, and that's that. But being in the driveway makes it a little trickier. I can get asphalt by the bag to patch the driveway, but I don't want the holes to settle after that. Should I just fill each hole with dry sand so there is no settling, then top off with asphalt to make it look as nice as possible? Or should I do something completely different?
l008com is offline   Reply With Quote
Old 06-08-2015, 03:50 AM   #2
Rewards Points: 1,480
Part 2:
Jack them out with 2 bumper jacks, floor jacks, scissor jacks or hydraulic port-a-powers after nailing/bolting a couple of 2x4s across them. Fill the holes with dirt and compact with a tamper in 6" lifts then asphalt to whatever thickness deeded.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
ron45 (06-08-2015)
Old 06-08-2015, 05:05 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,340
Ayuh,.... Fill the holes with crushed stone, 'n compact it as ya do,... not dirt,...
Old 06-08-2015, 07:34 AM   #4
Have you ever seen the highway department compact crushed stone when building a road? Probably not and there is a reason they don't.
Old 06-08-2015, 09:36 AM   #5
Rewards Points: 4,404
As SeniorSitizen said, jack it.
Then chisel jack the concrete just below the surface and fill with whatever your using for finished surface.
Forgot the important part..
One of these works well even with a 4 gallon compressor, just put the chisel in and go. makes really fast work of it.
http://www.harborfreight.com/Medium-...mer-69866.html
ron45 is online now   Reply With Quote
Old 06-08-2015, 10:00 PM   #6
Rewards Points: 996
an engine hoist would work, and be real easy to use. the only problem = if the post pulls out of the cement, and it could.
or. get a STRONG bar. drill hole in the post at the case. insert bar, one end on blocking. the other end on some kind of jack.
or, a sledge hammer.
Fix'n it is offline   Reply With Quote
Deck Post Advice Sallybeetle62 Carpentry 3 10-31-2014 06:51 AM
Deck Post Lighting obxbnd Building & Construction 7 08-09-2012 08:44 AM
Deck Post repair HobbyMan Building & Construction 5 07-14-2012 02:06 AM
Beam to post question for a deck... dbldee20 Building & Construction 0 06-04-2012 09:24 AM
basement post removal rb76 Building & Construction 6 06-13-2009 09:43 AM
