Deck Over Concrete - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By stick\shift
  • 1 Post By Guap0_
  • 1 Post By joecaption
  • 1 Post By MTN REMODEL LLC
Old 03-29-2018, 03:19 PM   #1
Rewards Points: 6
Deck over concrete
I think this is the right place to post this, but if not, I apologize.
I have a 10x12 concrete patio that I would like to put a wood deck over. I plan to use a sleeper system with spacers to attach the deck. The concrete is just about at grass level and there is a <6" step up into the back door. The question I have is how to extend the deck since it just isn't big enough for us. Drop concrete tubes into the ground to add attachment points? Deck blocks? Pavers? Something else? Any help or guidance would be greatly appreciated.
vucatsengr is offline   Reply With Quote
Old 03-29-2018, 03:45 PM   #2
Rewards Points: 4,170
Re: Deck over concrete
Low decks deteriorate faster since they don't get airflow beneath them. I would add onto the patio.
joecaption likes this.
stick\shift is offline   Reply With Quote
Old 03-29-2018, 04:06 PM   #3
Guapo
Rewards Points: 11,950
You need footings through the concrete patio & footings, in the grass. I don't know where you live so I can't comment on the depth (frost line). The footings have to go to the frost line whatever that is. I wouldn't use a ledger board. Build it free standing.
Guap0_ is offline   Reply With Quote
Old 03-29-2018, 07:36 PM   #4
Rewards Points: 17,912
Please post a picture so we can see what your seeing.
PS no deck should ever be even with any door openings!
Msradell likes this.
Old 03-30-2018, 07:12 AM   #5
Rewards Points: 1,858
On our previous home we downsized from, I had the same problem covering up a old concrete structure from a old enclosed porch it had removed from it by the PO's. It would have been too labor intensive and costly for me to remove, as it had concrete walls and footings under it.
Since I planned on building a "lean to style" porch roof over it anyway , the deck I built on the concrete was not a issue for me. The water never got close to the back entry slider door on the 5 quarter planks I used . As I also "crowned" the joists in the center some, so the planks would drain side to side outwards gently, from the high point in the center.
Gregsoldtruck79 is offline   Reply With Quote
Old 03-30-2018, 08:58 AM   #6
Rewards Points: 4,406
Nice looking yard.
ron45 is offline   Reply With Quote
The Following User Says Thank You to ron45 For This Useful Post:
Gregsoldtruck79 (03-30-2018)
Old 03-30-2018, 09:06 AM   #7
Rewards Points: 6
I'm trying to post a link to the article on Family Handyman, but I'm not allowed to post links yet. The article is titled "How to Build a Deck Over a Concrete Patio" and it explains how to install treated 2x4s as sleepers with pvc spacers for air flow.
I'll take photos this evening when I get home, but there really isn't anything to the patio. It's a concrete slab with a step up to the back door that's about 6".
Old 03-30-2018, 09:12 AM   #8
Guapo
That's not code in a lot of places. It's not structural.
Old 03-30-2018, 09:18 AM   #9
Rewards Points: 6
How could I look that up for my municipality? What should I look for?
Old 03-30-2018, 09:26 AM   #10
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,238
GREGSOLD......
Nice x-mas lights buddy........ looks great.
It's about time to take them down now isn't it....?
(Just kidding)
Gregsoldtruck79 likes this.
MTN REMODEL LLC is offline   Reply With Quote
Old 03-30-2018, 09:34 AM   #11
Guapo
Since all municipality sites are different, I would use what's called a google operator. Some people call them dorks. Let's say that the site is mymunicipality.gov
In Google, type
site:mymunicipality.gov intext:deck
Make sure that you leave a space between gov & intext. That search will give you every page that has the work deck in it.
Old 03-30-2018, 10:01 AM   #12
Originally Posted by MTN REMODEL LLC View Post
GREGSOLD......
(Just kidding)
LOL.....
Our departed Golden dog is just wondering.... what's up with my dudes eyeballs tonight anyway ??
Old 04-03-2018, 09:42 PM   #13
It's fine...
https://www.familyhandyman.com/patio...atio/view-all/
Also.
https://www.familyhandyman.com/patio...vers/view-all/
Old 04-04-2018, 12:55 AM   #14
Guapo
I didn't realize that the deck was going to be under 18" off the ground.
Old 05-03-2018, 09:48 PM   #15
I saw the same article and I am planing on using those plans. If the 2x4’s are layed on its side with pvc shims under them then how far apart is the spacing between each shim? Is 16 inch to far apart? I was thinking 12 inches
Bgalls88 is offline   Reply With Quote
Building My First Deck - Am I Headed In The Right Direction? minker17 Building & Construction 5 03-07-2017 04:56 AM
Help deciding deck plan with a partial concrete pad msajeep Building & Construction 0 05-31-2016 07:26 AM
waterproofing metal pan concrete deck fatboyelroy Concrete, Stone & Masonry 10 02-09-2013 02:09 PM
Deck over concrete patio PAmbrose Building & Construction 16 08-21-2012 10:23 PM
Deck clearance over concrete miles Building & Construction 4 09-19-2009 06:24 PM
