Dealing With Excess Rain Water - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By Drachenfire
  • 1 Post By Bondo
  • 3 Post By lenaitch
Old 07-26-2017, 09:57 AM   #1
Rewards Points: 1,052
Dealing with excess rain water
My neighbor tore his house down and rebuilt. Now all the water from his front yard drains over to my yard, picks up mulch and dumps it on my garden on its way to a lake in the backyard.
Ground is about 8' of trucked in dirt over shale.
I realize the neighbor is legally responsible for dealing with his water; but that's not going to happen, so moving on...
I have had three proposals for dealing with it; all about the same price.
1) Burying a perforated pipe on the low spot and draining to the lake. Covering the pipe with cobbles.
2) installing 3 drain boxes and running them to an existing downspout drain that goes to the lake.
3) Excavating the low spot and filling it with rocks. At the end of the line of rocks, digging a large drywell. Drywell would start about 15' above lake level.
Guy two says the DEC would never allow a new drain to the lake, but an existing drain is grandfathered. Neighbor was required to run his downspouts to a drywell rather than running them to the lake; FWIW. He also doesn't like perforated pipe as it will clog up. (He feels certain the existing drain would have plenty of capacity to handle the ground water as well as the roof water; I am not so sure)
Guy three doubts using the existing drain for a new purpose would be acceptable; hence the drywell.
Any thoughts on these three proposals would be much appreciated.
We have had several rains of 3" in an hour this year; neighbor across the street says there has only been one such rain in the 15 years he has lived there; but it seems to be trend that has to be dealt with.
Toller is offline   Reply With Quote
Old 07-26-2017, 10:24 AM   #2
retired framer
Rewards Points: 20,676
Re: Dealing with excess rain water
For the same money I would go with the dry well and have it closer to the lake.
Sooner or later you will have to deal with that pipe too. If you have the dry well that will not be hard.
Old 07-26-2017, 12:34 PM   #3
ZTMAN's Avatar
Rewards Points: 342
I would rip your house down, rebuild, and throw the water back over to him.
Now that I got that out of my system, I would look at the grading plan he filed with his permit . Something has to be amiss. If you don't think the neighbor will work with you for a joint solution, then I would do what Neal recommends
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 07-26-2017, 12:50 PM   #4
Big Dog
Drachenfire's Avatar
Rewards Points: 4,002
I had a similar drainage problem whereby heavy rains would cause water to collect at a downstairs sliding glass door and would flood the living room were it not for the sump system I jerry-rigged to move the water around the house. My fear was a power outage during one of those storms.
I had a landscaper come in to address the issue.
He dug a trench from the high corner of the house across the door just beyond the patio, around the other end of the house and down to the low corner of the property. In the trench, he laid in a sleeve covered 4” pipe. At the high corner he connected it to the down spout. Across the door he installed two 12” catch boxes connected in series with the pipe. On the low side he connected the second down spout. At the end he installed a pop-up diverter.
When it rains, water that would normally collect at the door goes down the catch boxes. The water runoff from the down spouts not only keeps excess water out of the backyard, it also helps flush the pipe.
Drachenfire is offline   Reply With Quote
Old 07-26-2017, 12:59 PM   #5
retired framer
He dug a trench from the high corner of the house across the door just beyond the patio, around the other end of the house and down to the low corner of the property. In the trench, he laid in a sleeve covered 4 pipe. At the high corner he connected it to the down spout. Across the door he installed two 12 catch boxes connected in series with the pipe. On the low side he connected the second down spout. At the end he installed a pop-up diverter.
Next time don't let them use pipe with a sock what you want is gravel to allow the water to run in and fabric to protect the grave from being filled with mud. The pipe is just s whole in the gravel for water to run thru.
If they use a sock instead of fabric over gravel the mud fills the gravel and the sock so it needs to be redone much sooner.
It is a make work program.
Old 07-26-2017, 07:07 PM   #6
Big Dog
Well, it was installed some four years ago and so far no issues.
Nealtw likes this.
Old 07-26-2017, 07:26 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Ayuh,..... What sorta terrain is 'tween the low spot, 'n the lake shore,..??
Docks,..?? patio,..?? clear space,..??
If clear space,....
Just cut a slight swale, 'n let it flow, naturally back into the lake,....
lenaitch likes this.
Old 07-26-2017, 09:29 PM   #8
Usually Confused
lenaitch's Avatar
Rewards Points: 2,210
If it is clear ground, I like Bondo's idea of a swale. A shallow, grassed linear depression leading to the lake should re-direct the water.
Assuming your municipality has enforceable building and property standards, if your neighbour was required to have an approved site plan which should have addressed surface water management, then it should be up to the municipality to enforce it - with or without your neighbour's cooperation.
Bondo, Msradell and Nealtw like this.
lenaitch is offline   Reply With Quote
Old 07-31-2017, 11:37 AM   #9
There is a swale there now; the water sweeps all the mulch from the swale and dumps it in the garden, which is down hill of the swale. So it ruins the land around the swale, and the garden.
I want to intercept the water in the swale (by means of a perforated pipe, drain boxes, or rocks) and keep it away from the garden (by neans of a perforated pipe pouring into the lake, a drywell, or a pipe into the existing downspount drain).
Old 07-31-2017, 03:51 PM   #10
Bondo's Avatar
Ayuh,.... Can ya move the swale, or pitch it Around the garden to the lake,....
If ya use any sorta Pipes, ya fall under codes 'bout water discharge,....
If the water just runs into the lake,... No codes involved,...
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Help! Yellow Hot Water mechetti Plumbing 1 11-01-2012 08:57 PM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
