Cut Tree - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-16-2016, 08:06 AM   #1
Rewards Points: 996
cut tree
i have these med sized trees on the side of my yard. if i were to cut them about 6' high, is there something i can do to make them keep growing from the trunk ?
Fix'n it is offline   Reply With Quote
Old 04-16-2016, 08:18 AM   #2
Rewards Points: 6,128
Re: cut tree
What kind of trees are they. I don't all of the ones that re-grow, but I have experienced maples (native Maine variety) and white birch (several varieties) will turn into a bush very quickly. Usually, one or two dominant sprouts will become trees over time.
Bud
Bud9051 is online now   Reply With Quote
Old 04-17-2016, 06:43 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Re: cut tree
Ayuh,... Agreed, it depends on the species,....
Old 04-17-2016, 07:21 AM   #4
Re: cut tree
The alternative to having a tree that will regrow from the root would be to graft branches from above and get them established (long time) and then cut the tree off and have a shorter tree. The long time is because the new branches will need to be established enough to feed the remaining tree. The tree people should be able to advise.
I have never attempted grafting, but have seen apple trees with multiple varieties doing nicely.
Bud
Old 04-17-2016, 07:49 AM   #5
Rewards Points: 996
Re: cut tree
thanx guys. idk what they are, i think maple and some kind of berry.
Old 04-17-2016, 08:32 AM   #6
Re: cut tree
How big is the tree? Any old leaves laying around. Maples are easy to identify and the ones I cut immediately sprouted new shoots from the stump.
BTW, is this tree close to the house?
Bud
Old 04-17-2016, 09:22 AM   #7
Rewards Points: 996
Re: cut tree
the trunks are about 1'ish diameter and about 50' tall.
not close to houses at all. cept for when i go to cut them lower, i will have to be carefull.
Old 04-17-2016, 11:08 AM   #8
Re: cut tree
If you want a 10' tree with branches, that would take grafting. If it regrows from the roots, it will start from ground level and come up as multiple small trees. Being that big, IMO, I would remove it and the stump and plant what I wanted.
I also don't think the suckers that propagate from a cut stump will result in the shape of a tree you would like. The old stump remains as part of the root ball and as it decays it leaves the tree open to infestations. Just my opinion.
Planting new allows you to start with a bigger tree and place it exactly where you want.
Bud
Old 04-17-2016, 12:52 PM   #9
Rewards Points: 4,246
Re: cut tree
This is a little over the top but still has interesting information.
http://www.growingagreenerworld.com/...ng-your-trees/
Nik333 is offline   Reply With Quote
Old 04-17-2016, 05:33 PM   #10
Bondo's Avatar
Re: cut tree
Ayuh,... Depends on the species,...
Box Elder, aka: california maple, stumps will kepp regrowin', til ya pull it out, 'n ya gotta get All of it out,...
'ell, cut firewood will sprout from the bottom of the woodpile,....
Big Willows will re-sprout a trunk, regardless how low ya cut it,....
Old 04-19-2016, 09:50 AM   #11
Rewards Points: 806
Re: cut tree
If you have a 50' tree, you can't expect to cut it at 10' and have it survive or look anything like it's suppose to. Some shrubs that grow out of control could be pruned excessively, but if I want a 50ft maple to be 10 ft because it's filling up my gutters, that's not an option. Cut the whole tree down and replant something that won't get very tall. I have a feeling you'll be quite disappointed if you try something else.
cibula11 is offline   Reply With Quote
What is this tree / Pests eating the fruit Zyclone Landscaping & Lawn Care 2 08-11-2015 09:29 PM
Transplant tree near underground utility lines? BrandonC_1972 Landscaping & Lawn Care 11 08-26-2012 05:43 PM
Apple Tree Care bgibson11 Landscaping & Lawn Care 9 05-28-2011 08:28 AM
Extending deck around a tree jcgoldie Building & Construction 2 02-15-2011 05:20 PM
