Thread Tools | Display Modes |
#1 |
Rewards Points: 590
![]() cub cadet cut issue
This started the end of last mowing season and I forgot about it until today when I was mowing. The grass was as long as it's been all year so far so it was easy to notice. For some reason the mower is leaving a thin line of grass uncut down the middle. It's a 42" deck and only has 2 blades. Deck appears to be level when I put my level on it. What could cause this and how can I fix it. Mower is only 2 years old. It's annoying having to retrace my steps to get spots I know I didn't miss.
Sponsored Links | |||
Advertisement |
#2 |
Rewards Points: 404
From your description, it seems you need new blades. They have become worn enough to leave the thin streak of uncut grass.
RR ![]() ![]() |
The Following User Says Thank You to Rough Rooster For This Useful Post: |
joecaption (07-17-2015)
Advertisement |
#3 |
Rewards Points: 1,332
The blades may be dull enough that they are not cutting. I find that I have to sharpen my mower blades about every 7-8 cuttings if I want them to cut well. After that I get poor cutting quality (for my standards). Keep in mind that I am cutting roughly 1/2 acre.
Advertisement |
#4 |
Rewards Points: 384
If the grass was high, the thin strip usually comes from the anti scalp rollers mid deck pushing the grass down, and there is not enough vacuum from the deck to give it a clean cut. I dont know if that small of a mower has the rollers mid deck but you can tell if this is the issue by slowing down. The slower you go the better the cut
#5 |
Rewards Points: 590
Thanks. I'll try replacing g the blades since I have hit a few tree roots since I got the mower. It doesn't have anything between the 2 blades either. I want mulching blades anyway.
#6 |
Rewards Points: 590
Just an update. I replaced the blades and man were those old ones in bad shape! Took my impact drill to get the nuts off of them things too! Glad it was an easy fix.
The Following User Says Thank You to nikeman For This Useful Post: |
GrayHair (07-18-2015)
#7 |
Rewards Points: 2,828
#8 |
Rewards Points: 18,118
I always apply some antisieze to the bolts to make it easier next time.
The OEM blades on my new mower only lasted 20 hours. And where almost worn in 1/2. I ordered some Oregon brand Heavy duty Gater blades that are .050 thicker, 1/2 wider and made with Titaniam in the steel. 20 Hours and they still look like new, and are still sharp. The OEM blades where about $70.00 a set, these where $80.00. Well worth the extra money.
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
#9 |
Rewards Points: 590
I bought a mulch kit at home depot with the 2 blades and a plug for about $50. Prob not the best blades but 10x better than what was on the lower. Not sure about the plug yet since the lower seems to work a lot harder with it on although the grass was longer than I usually let it get. Normally I now every week but it was 2 weeks this time around due to lack of time. I'll give it one more chance next week to see if I keep it on.
#10 |
Rewards Points: 1,388
Thanks for posting your resolution. Always nice to learn the final outcome.
#11 |
Advertisement |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Trane XR90 issue | jasun | HVAC | 7 | 10-08-2012 07:18 PM |
HVAC condensor fan outside intermittant | wheelsup | HVAC | 21 | 05-24-2012 11:25 AM |
Westinghouse furnace issue | joe8918 | HVAC | 9 | 12-04-2011 06:50 PM |
how to reduce mositure issue on basement? | diy001 | Building & Construction | 0 | 10-28-2011 01:44 PM |
Perplexing AC issue | AvalonGirl | HVAC | 22 | 08-17-2011 07:49 PM |
