Creeping Charlie - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-08-2013, 09:32 PM   #16
Rewards Points: 996
Originally Posted by chitownken View Post
Just follow the instructions on the container. Hook it up to the hose and soak down the area with the creeping charlie. I used pump sprayer with the WBG concentrate, but I had 3/4 acre to clear out. Hit it now and hit it again in early to mid October.
i bought the one where i have to pump the container and use the crappy sprayer on it. these things are a real pita. i think i will return it and get the concentrate.
Fix'n it is offline   Reply With Quote
Old 08-09-2013, 09:42 PM   #17
chitownken's Avatar
Rewards Points: 510
The hose end sprayer is probably the easiest to use if you have a hose long enough to reach the area. I have a 15 gal sprayer that gets towed behind my mower that gets used for weed killer and insecticide. If you can't find the hose end version, get one of the 2 gal pump up sprayers that you can put your own mix in. They are much nicer that the crappy ones you get with the pump up packaging at the store.
chitownken is offline   Reply With Quote
Old 08-10-2013, 09:05 AM   #18
Rewards Points: 996
i have a 1/2 gl pump somewhere. i also bought the concentrate.
Old 08-10-2013, 09:33 AM   #19
chitownken's Avatar
Rewards Points: 510
How big an area do you need to spray? One other thing, if it is in your neighbor's lawn as well, you will have a hard time keeping it from coming back unless they kill it off as well.
Old 08-10-2013, 09:51 AM   #20
Rewards Points: 996
for starters, i am going do a 10x10 area, until i get a handle on what works. but i have many a square that has it
Old 08-11-2013, 10:46 AM   #21
Rewards Points: 996
ok. i sprayed 2 test areas = if the grass dies there, no problem.
what i am wondering = how long should i wait to see if it is working ?
Old 08-11-2013, 04:58 PM   #22
chitownken's Avatar
Rewards Points: 510
Took about a week for it to start showing results when I did it. The CC started to turn brown on the edges and started to shrivel up. Kind of depends on how much rain you get.
Old 08-11-2013, 08:57 PM   #23
Rewards Points: 996
ok, gotcha
Indoor MR16 soffit questions josephnyc Electrical 10 03-19-2013 07:25 AM
Roll, then cut? Yeti Painting 9 02-06-2013 05:32 PM
Creeping Charlie Removal McSweny1103 Landscaping & Lawn Care 2 09-12-2012 07:58 AM
Creeping Charlie Zee 32 Landscaping & Lawn Care 7 11-18-2009 01:37 PM
Creeping Charlie 2031pratt Landscaping & Lawn Care 2 08-05-2009 10:27 PM
