Corrugated Pipe Adaptors - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-11-2017, 10:06 AM   #1
Rewards Points: 2
Corrugated pipe adaptors
I installed a French drain yesterday and after filling in the end of the trench ahead of where the pipe ends with gravel the gravel likes to find its way into the pipe. I bought an endcap that has holes in it to stop that but it doesn't fit on that end of the pipe. I know one end is larger so that 2 pieces can connect to each other so is there also an adaptor to fit the small end?
robman123 is offline   Reply With Quote
Old 06-11-2017, 10:37 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,222
Re: Corrugated pipe adaptors
Even corrugated pipes come in male and female. It is possible you need a coupling to mate the two together. http://www.homedepot.com/p/4-in-Poly...12AA/100181960
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Need watertight connection between 4" corrugated drain pipe and 4" PVC (sched 40) homeimproverjoe Plumbing 9 04-28-2017 06:35 AM
Best pipe to use without sag for projection screen scampy74 Home Theater 4 08-30-2016 10:27 AM
Perforated corrugated pipe Indiapaleale Landscaping & Lawn Care 3 04-01-2016 04:44 AM
Corrugated Drainage Pipe mobleyw Building & Construction 2 03-22-2016 06:11 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
