Cordless Mower Won't Start - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-04-2015, 01:17 PM   #1
Rewards Points: 4
cordless mower won't start
I have a Black & Decker CM1200 that stopped working all of a sudden. I've replaced the battery, but still no luck. With the cover off, I don't see any loose connections, and when I lift up on the safety handle, I do hear a click, though not consistently. I bet it's something simple, so I hate to give up on it just yet. Any ideas on what else it could be and how to check those parts? Thanks so much for your time!
jerrunyan is offline   Reply With Quote
Old 06-04-2015, 01:23 PM   #2
Rewards Points: 474
Just Google … Black & Decker CM1200 won’t run… and you will have an answer in about five minutes
http://www.manualslib.com/manual/169...-90514757.html
http://markselectricmower.blogspot.c...t-details.html
BrowneBearLLC is offline   Reply With Quote
Old 06-04-2015, 05:29 PM   #3
Rewards Points: 744
...and what is the answer?
Jerry, here is another informational lead: http://www.lawnmowerforum.com/black-...-re-start.html
You're gonna have to take it apart and start checking the wiring circuit.
Seattle2k is offline   Reply With Quote
Old 06-05-2015, 11:03 AM   #4
Rewards Points: 4
Thank you, BrownBear and Seattle, for your responses. I have spent hours looking online, but I cannot find much information on how to diagnose or fix cordless mowers. I'm really surprised at the lack of information out there.
I'm generally pretty handy, but I have limited experience with electrical repairs. Would you mind explaining how I might check the wiring circuit? I have a voltmeter, but I'm not sure what I'm checking for on the mower.
Thanks again for your help!
Old 06-08-2015, 06:46 AM   #5
Rewards Points: 2,372
Really need to see if the motor is getting adequate voltage when the "cut" switch is activated. If it is and still does not turn then you likely have a motor problem.
If the motor doesn't' see the right voltage, then you've a supply/switch issue.
bob22 is offline   Reply With Quote
mower won't start Startingover Tractors & Mowers 33 10-13-2013 01:23 AM
Craftsman Riding Mower won't easily start (video) mikestorm5 Tractors & Mowers 7 08-18-2013 08:34 AM
Lawn mower starts then dies gazz87 Landscaping & Lawn Care 8 11-19-2011 01:43 PM
Help choosing between these cordless power drills and why for a 1st timer? amlodipine Tools 21 09-23-2011 11:23 PM
Solaris Lawn Mower review dive_instructor Landscaping & Lawn Care 0 06-03-2011 09:29 AM
