Contractor Hose Fittings - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree10Likes
Old 06-15-2020, 07:41 AM   #1
DoomsDave's Avatar
Rewards Points: 14,036
Contractor Hose fittings
Not sure if this belongs here or somewhere else, but here goes . . .
I have a 3/4" contractor hose and can't find fittings that fit it. The male hose end replacements I've found are too small, made to fit 5/8 - 3/4 as opposed to "full-blooded" 3/4 like this one.
I've got the other smaller size too, and the difference is readily apparent. The barb is not tight enough and water leaks, and simply cinching a clamp down tighter doesn't work.
Any thoughts on where to find fittings that will fit?
Hate to toss a perfectly good hose that's sturdy as stone except for the [expletive] fittings.
Life is one long teaching moment.
DoomsDave is offline   Reply With Quote
Old 06-15-2020, 08:03 AM   #2
retired framer
Rewards Points: 15,546
Re: Contractor Hose fittings
Anywhere but a box store.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 06-15-2020, 08:29 AM   #3
DoomsDave's Avatar
Regular hardware stores don't have them, either.
Old 06-15-2020, 08:41 AM   #4
retired framer
https://www.amazon.com/Garden-Repair.../dp/B0814VG6WQ
DoomsDave likes this.
figure 7-14
Old 06-15-2020, 09:03 AM   #5
DoomsDave's Avatar
Originally Posted by Nealtw View Post
Thanks, saw them, too. Looking for a local retailer if possible.
Maybe contractor's supply . . . . .
Nealtw likes this.
Old 06-15-2020, 10:08 AM   #6
Rewards Points: 6,486
COPIED AMAZON:
" Proper size:
The diameter of brass garden hose mender is approx. 17 mm/ 0.67 inches, easy to connect the 3/4 inch hose for easily insert and remove hoses, please check your hose size before purchasing."
Think about this a second and we might see where at least some of the problem lies in the above statement from Amazon.
If i recall 5/8" in decimal form is 0.625". Amazon lists their barbed fitting as 0.67" which would be a push fit into a 5/8" hose, perfect for a 0.045" interference fit. But what does Amazon say - " easy to connect the 3/4 inch hose for easily insert and remove hoses, please check your hose size before purchasing " .
OH BOY, now if we could only have more metric system involved in this screwed up mess. Kind of disappointing only 17 mm was only mentioned.
SeniorSitizen is offline   Reply With Quote
Old 06-15-2020, 10:26 AM   #7
retired framer
Originally Posted by SeniorSitizen View Post
COPIED AMAZON:
" Proper size:
0ne inches = 26 mm
figure 7-14
Old 06-15-2020, 10:40 AM   #8
DoomsDave's Avatar
@SeniorCitizen and @Nealtw , your travails are why I want to hold in my sweaty palm before I buy. Better for all.
Nealtw likes this.
Old 06-15-2020, 10:42 AM   #9
Rewards Points: 712
I prefer to buy local as well, and would bet that someone within a reasonable distance has them on the shelf. I don't know how they are all related, and assume there are other chain names in various parts of the country, but one thing I noticed years ago is that not all Ace's are the same and not all True Value's are the same. I have an Ace store in one direction that is pretty good any more, a lot better than it used to be, which I believe is more of a "company store. I have another Ace store in the opposite direction, Ace name all over, inside and outside, but it still carries the old family name as well, and that's the one where I would go for a left hand thread nut, biggest assortment of metric screws and nuts, and things like the hose end that the other one didn't have. And then there's True Value, which I generally think of as second to Ace, but we have an independent one of those a little farther away, Tru Value inside and out, still locally owned and operating under their long time independent name, and that's where I go for things that "nobody is going to carry", because sure enough they usually have it.
Old 06-15-2020, 10:57 AM   #10
That's the #1 reason i don't purchase on line. If the idiots ever give some accurate details about the item maybe, but i doubt that will ever happen as long as success is in selling items that don't fit.
Concerning the hose i repaired just recently, i snipped a inch piece and took it to Ace hardware and even then there is some question. So i discovered a way of sizing without looking like a nurd and taking my vernier caliper. That particular little hanging display of theirs can be dis-assembled to test fit and be re-assembled if rejected. Sometimes it pays to be an old IE major.
OH, BTW -- one of the plastic male repair fittings seems to have a thread pitch maybe a half millimeter off from the old USA standard so it gets forced as usual.
Old 06-15-2020, 11:05 AM   #11
retired framer
I worked for an outfit that repaired hoses, all our bits and pieces came from a local company that sold to all the fire dept.s
figure 7-14
Old 06-15-2020, 11:12 AM   #12
kwikfishron's Avatar
Rewards Points: 470
I'd think Grainger would have them and I'm sure there's a location near you.
Nealtw and DoomsDave like this.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
DoomsDave (06-15-2020)
Old 06-15-2020, 11:40 AM   #13
Oso954's Avatar
Rewards Points: 1,872
0ne inches = 26 mm
The precise value is 25.4 mm per inch.
Oso954 is offline   Reply With Quote
Old 06-15-2020, 11:49 AM   #14
I don't need to look on charts or even think anymore because Siri has that all knowed up.
Mike Milam likes this.
Old 06-15-2020, 01:29 PM   #15
DoomsDave's Avatar
Thanks for the tip!
There is one, but they've gone curbside, which I was also hoping to avoid. I want to look and see before I buy, not guess and hope.
But I'll keep looking.
