Connectors For Low Voltage Lighting? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-04-2018, 10:07 PM   #1
Rewards Points: 72
Connectors for Low Voltage Lighting?
Any suggestions for good connectors for a low voltage landscape lighting system? Started off with the Malibu style that mostly work by 'piercing' the cable. They seemed to fail after a few years. The last thing I've tried were these
'Nano-Junction' connectors from Volt Lighting: https://www.voltlighting.com/nano-ju...-VAC-WC2-PBK-2
They do seem to have an excellent design.
Just don't know how long they might last.
Thanks for any thoughts or advice!
randyw57 is offline   Reply With Quote
Old 04-05-2018, 05:42 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 636
Re: Connectors for Low Voltage Lighting?
Looks like a Wago in a gel pack. Nice but expensive. I use gel filled wire nuts.
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 04-05-2018, 09:57 AM   #3
Rewards Points: 1,251
I also only use gel filled wire nuts. Never had an issue with them.
KHouse75 is offline   Reply With Quote
Old 04-05-2018, 11:38 AM   #4
Rewards Points: 72
Thanks rjniles and KHouse75!
I've used those gel filled nuts as well.
They seem to be holding.
Thanks for the pointer to those Wago's.
I've used their push-in connectors.
The ones with push down levers look even better.
Well, nobody suggested those 'piercing' style connectors.
I believe I've got all of mine replaced now.
Thanks again!
Old 04-06-2018, 11:35 AM   #5
Dave Sal's Avatar
Rewards Points: 1,150
I've had Malibu low voltage lighting on my house since about 1981. I've always used the pierce type connectors but in the last few years have been plagued with failures. I decided to just remove them and solder the light fixture connections instead. Problem solved.
Dave Sal is offline   Reply With Quote
Old 04-06-2018, 11:43 AM   #6
Rewards Points: 72
Hi, Dave Sal!
Well, I bet soldering will definitely work.
That's a great idea.
Do you tape the connections? Or heat shrink?
Old 04-06-2018, 01:09 PM   #7
Dave Sal's Avatar
Originally Posted by randyw57 View Post
Hi, Dave Sal!
I'm using heat shrink tubing. So far, and it's been a few years since I started doing this, no more failures.
Old 04-08-2018, 10:19 AM   #8
Rewards Points: 72
Yep, Dave Sal, I believe that is a pretty bullet proof solution.
Tags
electrical connection , landscape lighting , low voltage system
Test Voltage In Lutron Lighting System meliisaranger Electrical 9 10-05-2015 01:45 PM
Low voltage Lighting issue ccbdiver Electrical 2 02-22-2015 06:56 PM
Low Voltage LED Lighting Cultcab Electrical 19 07-13-2012 03:37 PM
switching low voltage lighting handifoot Electrical 1 04-27-2010 08:08 AM
Low voltage under cabinet lighting question fishacura Electrical 6 03-29-2010 06:57 AM
