Concrete Around Drain? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-18-2017, 08:06 PM   #1
Rewards Points: 92
Concrete around drain?
Good day all,
I have a few drains set around my yard to help get rid of surface water.
[ATTACH]415273[/ATTACH
Do you think it is best to fill the area around the drain with cement of just fill it with clay-heavy soil (so that the water doesn't absorb that much in the soil before going into the drain)?
cedricmeier is offline   Reply With Quote
Old 08-18-2017, 08:08 PM   #2
ZTMAN's Avatar
Rewards Points: 340
Re: Concrete around drain?
Dirt.
The drain is to take away excess water.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 08-18-2017, 08:09 PM   #3
Rewards Points: 92
Originally Posted by ZTMAN View Post
Dirt.
Thanks bud. I'm guessing the clay-heavy stuff that was there before is good enough?
Old 08-18-2017, 08:12 PM   #4
Rewards Points: 92
Also, do you think i should use some cement in the hole first just to keep everything tight in place before filling the rest with the soil?
Old 08-19-2017, 07:17 AM   #5
ZTMAN's Avatar
Rewards Points: 340
No cement. Dirt will do just fine.
Running new kitchen drain because 1953 wasn't friendly with connection height scgt1 Plumbing 16 02-03-2017 11:57 AM
Shower Drain in Concrete Slab Install sharp21 Plumbing 4 08-30-2012 10:51 AM
connecting clawfoot tub to existing drain line in concrete basement michaelflinn Plumbing 0 07-02-2012 04:48 PM
Damaged PVC drain needs removed from concrete floor bfensler New Member Introductions 1 01-17-2011 11:02 PM
Adding exterior drain with concrete steps in way steveel Building & Construction 5 09-10-2010 04:23 PM
