Clearing A Wild Back Yard - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 1 Post By ianswatson
  • 1 Post By Colbyt
  • 2 Post By Nik333
  • 1 Post By CosmicMiami
  • 2 Post By HenryMac
Old 10-20-2018, 01:55 PM   #1
Rewards Points: 2
Clearing a wild back yard
Hi all,
I'm looking to clear my back yard overgrown with saplings, vines, etc. and replace with something more appropriate for using the space. I'm sure it would be ideal to clear it all out then scrape the top layer of soil off with heavy equipment and sow grass. But not only is that expensive, the land is steep and uneven and that would be difficult anyway.
I'm open to ideas. The best I've found so far is to cut everything down and then dig it out with pickaxe and shovel and fill in the holes, then sow grass. Grass would be great. But it's shaded almost constantly from large trees. So, it doesn't have to be grass. But I do want to be able to walk around.
Thanks!
MurphyMan likes this.
ianswatson is offline   Reply With Quote
Old 10-20-2018, 02:54 PM   #2
Rewards Points: 7,015
Re: Clearing a wild back yard
I would tackle that with a brush cutter attachment on my string trimmer cleaning up the mess as go.
Spray anything that dares to stick its head back out of the ground to kill it.
Evaluate, selectively thin saplings and brush, treat the stumps with a stump killer or use that big tree, a log chain and a come-a-long to pull them out.
Bondo likes this.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 10-20-2018, 03:31 PM   #3
Rewards Points: 1,590
Soil erosion is always a concern on steep terrain. Consider a plan to do this in narrow sections across the slope beginning at the lower and progressing up the slope. This will take some time and shade tolerant grass may also need to be a consideration. If you have a county extension service they are often a great help.
Old 10-20-2018, 04:41 PM   #4
Guapo
Rewards Points: 11,950
Hire some day workers. They will clear the land in a few days. Then you can decide what to do with it.
Guap0_ is offline   Reply With Quote
Old 10-20-2018, 05:44 PM   #5
Rewards Points: 4,364
I don't know where you are But N. California rents herds of goats to clear underbrush. It's a real business. They come with fencing & graze for several days.
Have goats will travel & Rent a Goat pop up many options.
Bondo and firehawkmph like this.
Nik333 is offline   Reply With Quote
Old 10-20-2018, 06:27 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Ayuh,..... Ya don't wanta remove any of the soils, just the junk now livin' in the soils,....
With heavy equipment, the dirt stuck to the junk ya remove is collateral damage to get the job done,.....
Colby's idea is probably how I'd go 'bout it,....
My weedwacker with a brush blade is an awesome tool,....
What it won't take down, I've got chainsaws that will,.....
To regreen the ground as yer carryin' out this task, scatter white clover seed on any exposed dirt,.....
It'll turn the ground Green, in most lightin' conditions, 'n most climates,.....
A side bonus is, it fixes nitrogen into the soil,.....
'n it grows 'bout knee high, ain't even gotta mow it if ya don'y wanta,.....
Old 10-21-2018, 04:50 AM   #7
retired painter
Rewards Points: 1,864
Whenever feasible it's better to dig around a tree/sapling's trunk and then either hook a chain to pull it down or push it over. That has the advantage of using the tree's weight to help bring it down and the roots [or some of them] up.
mark sr is online now   Reply With Quote
Old 10-21-2018, 08:53 AM   #8
Rewards Points: 315
Consider a native landscape for your yard. I'm not a fan of just tearing stuff out and growing grass. As somebody mentioned above, it appears to be sloped. It's not as if you will be playing ball or anything on a sloped yard. Maybe do some paths and plant some shade tolerant native plants.
cat's_pajamas likes this.
CosmicMiami is offline   Reply With Quote
Old 10-21-2018, 09:40 AM   #9
Rewards Points: 576
What is your location....how large an area do you want to improve ? Offhand, either you or some helpers could create a 3 foot wide path, down to soil level and pull, cut or dig offending trees, roots and shrubs......so you can "just walk around." Leave most everything else alone. You can add large pavers for steps...or use 3 foot pieces of PT 4x6 (or RR ties) and decomposed granite to make larger steps or landings.
Cedrus is offline   Reply With Quote
Old 10-21-2018, 10:52 AM   #10
HenryMac's Avatar
Rewards Points: 1,002
I'd cut in some walking paths and leave it as is. Looks like a beautiful area.
ChuckF. and cat's_pajamas like this.
HenryMac is offline   Reply With Quote
Old 12-06-2018, 09:00 AM   #11
DoomsDave's Avatar
Rewards Points: 5,710
Originally Posted by ianswatson View Post
Hi all,
Thanks!
Be careful what you do. Where is your place located? That's critical, because how much rain or other precipitation you get will make a difference. It will also help guide what, if anything, to plant in place of what you're taking out. Looks like Northeast Ohio, where I'm originally from, but let us know . . . .
DoomsDave is online now   Reply With Quote
Old 12-06-2018, 07:54 PM   #12
Rewards Points: 1,760
It looks nice actually, I agree with the walking paths idea, maybe a small picnic table in a small clearing. treated wood borders with fine gravel between, or pavers if you are more ambitious. Watch for poison ivy. Leave bigger trees and ground-cover plants, thin out the saplings. Work in some blooming perennials for color.
ChuckF. is offline   Reply With Quote
back yard lake ugggg Lisa&RayFrench Landscaping & Lawn Care 5 06-08-2016 03:50 PM
Back yard get's very soggy after rainfall vbreyter Landscaping & Lawn Care 1 06-02-2016 03:16 PM
Back Yard issues oefootball_70 Landscaping & Lawn Care 7 04-24-2013 03:56 PM
What is this strange grass in my back yard mmunro2003 Landscaping & Lawn Care 3 04-22-2013 09:18 PM
Severe Drainage Issue kirridam Landscaping & Lawn Care 11 07-25-2009 06:44 AM
