Cleaning A Curtain Drain Pipe - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-22-2015, 10:02 AM   #1
Rewards Points: 20
Cleaning a curtain drain pipe
Just discovered my newly purchased 1980's house had a curtain drain system installed by the builder.
There's a 4" white PVC pipe that exits roughly 150' back from my home at the rear property line along the edge of a small brook.
1. Is there a critter cap on the pipe? Of course not!
2. How should I clean this thing out before installing a critter cap?
It this as simple as renting a 100' snake or auger and running it up through the pipe to ensure nothing has clogged it up since the Reagan administration? Or is this a more complex task than I'm thinking it is?
bld3613 is offline   Reply With Quote
Old 05-22-2015, 05:46 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,.... I'd go to the Other end, the Highest point, 'n stuff a garden hose down it, 'n turn it on full blast,....
Then run down to the creek,...
There oughta be a Blast of water by the time ya get there,.....
Old 05-22-2015, 05:53 PM   #3
Rewards Points: 17,912
Is it plugged up?
Critter cap? A simple piece of 1/4 hardware screening will work.
Old 05-23-2015, 01:45 PM   #4
Rewards Points: 474
If it is plugged up you need to go to the opening and get some lengths of PVC attach a garden hose and start running it through the pipe.If it was built right you should not have a plug unless something crushed the pipe at some point.
BrowneBearLLC is offline   Reply With Quote
Old 06-05-2015, 10:34 AM   #5
Rewards Points: 20
Thanks BrownBear. That's what I'm going to do. I'm a bit suspect because we just had a very heavy rainfall over the past few days and I didn't see any water coming out of the pipe (although we've been in a drought prior to that)
I will also make sure to attach some mesh to the end of the pipe as some others have suggested.
Tags
drainage
Basement Framing And Drain Pipe blainekehl Building & Construction 9 02-21-2015 09:14 AM
replacing washer drain pipe robertkirkland Plumbing 51 08-12-2012 10:21 AM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 03:05 PM
sewer backup and stench jayhill Plumbing 12 08-13-2008 11:06 PM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 09:36 AM
