Clean Pavers Before Or After Installation? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By BabyUnicornTaco
Old 04-20-2018, 10:17 AM   #1
Rewards Points: 52
Clean pavers before or after installation?
Hey all. I have hundreds of Belgard pavers that I will be laying out for a patio. These pavers have been sitting outside for months and have the typical dirt, algae, water spots, etc., that you would expect when they have been left outside for a while. Is it better to clean these before or after they are installed? Is there a best recommended way to clean them? They are being installed with the typical rock, sand, and polymeric approach. Would soap and water work with a clean push broom for scrubbing after the polymeric has cured? I appreciate any suggestions. Thanks.
BabyUnicornTaco is offline   Reply With Quote
Old 04-20-2018, 10:49 AM   #2
JUSTA MEMBER
Rewards Points: 4,038
Re: Clean pavers before or after installation?
If they are still stacked in a pallet pile, the inner ones are not stained.
Clean any stains after installation.
TSP and a scrub brush.
ED
de-nagorg is online now   Reply With Quote
Old 04-20-2018, 01:08 PM   #3
Rewards Points: 52
ED
Thanks!
de-nagorg likes this.
Old 04-21-2018, 07:56 AM   #4
Rewards Points: 4,424
Just to be sure clean one first.?
ron45 is offline   Reply With Quote
Old 04-24-2018, 05:04 AM   #5
Rewards Points: 52
Good idea. Thanks.
Old 04-30-2018, 06:30 PM   #6
Rewards Points: 52
ED
So I installed the pavers. I applied the polymeric sand and it looks like I have some dirt stains that are in the polymeric sand. Not a good look. Any solutions? Apply another thin layer of polymeric after cleaning the entire patio? Special cleaner for the polymeric? I don’t like the look of a new patio that already looks five years old. I would like to fix this. I appreciate the suggestions.
Old 04-30-2018, 09:26 PM   #7
JUSTA MEMBER
Do you have a picture of what you are saying.
The polymeric stained the pavers, or something got in the polymeric, and got deposited in the spaces between the pavers, or ?
As stated before T S P to clean most patio surfaces.
T S P = Tri-Sodium Phosphate, a cleaner available at most BOX stores, Home depot, Lowes, Menards, etc.
ED
Old 05-05-2018, 04:25 PM   #8
Two Knots's Avatar
Rewards Points: 4,165
Our son gave us a bunch of old pavers that he ripped up from his yard.
The one I picked out for our outdoor bar top was stained.
The head knot sanded it with the circular sander, it came out
good...try sanding one and see how it comes out.
edit..I mean stained with dirt and grease etc...
Two Knots is online now   Reply With Quote
Old 05-05-2018, 04:48 PM   #9
Rewards Points: 52
ED
The sand in the joint is stained. Pavers are clean. It looks like dirt was sealed into the top layer of poly.
Setting the footing height for pergola posts and pavers? blue sky Building & Construction 5 03-14-2012 10:34 PM
Home Depot pavers vs Other Jstewart17 Landscaping & Lawn Care 6 03-02-2011 04:24 AM
concrete under pavers around pool deck , pavers go to edge of pool doggie44 Landscaping & Lawn Care 0 02-27-2011 10:40 AM
Water Seepage Under Pavers To Joist/Sill Plate BigNick183 Building & Construction 12 09-10-2010 04:49 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
