Cement Stamped Retaining Wall - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-09-2015, 02:58 PM   #1
Rewards Points: 2
I wanting to put in a retaining wall probably 40' long and 5' tall. basically I'm wanting to just frame in a wall with 2x4 studs and with 2x4 anchors, then cover the 2x4's with either 1/2" plywood or MDF" because I might be able to get those for free. Then I want to cover the wall in cement and stamp and stain it. I saw a how to website on how to this but they said you had to have pressure treated wood. I'm wondering if that's really necessary being that I'm going to sheet and cover it in cement, or if I can just use regular 2x4's.
shadow_amazing is offline   Reply With Quote
Old 07-09-2015, 04:47 PM   #2
Rewards Points: 17,912
I just can not picture that idea ever working out!
Old 07-09-2015, 05:36 PM   #3
Civil Engineer
Rewards Points: 5,246
Are you talking about using shotcrete over the plywood, troweled on mortar, troweled on concrete, or something else entirely? Are you planning to install rebar or mesh in the concrete? If you are planning to retain five feet of soil behind the wall, you need to do some calculations to verify that the wall will not overturn or slide. These calculations are not simple, you may want to get some help from an engineer on this project, especially since many municipalities require a permit for a retaining wall over a given height, four feet in many cases, due to the danger of collapse.
Tags
Replace Collapsed 4' Retaining Wall With Dirt Slope? gunner666 General DIY Discussions 4 08-07-2014 10:09 PM
Retaining wall first step height techdogg Landscaping & Lawn Care 4 08-07-2014 06:11 PM
Can you build a retaining wall in front of an old retaining wall? bb33 Concrete, Stone & Masonry 10 07-29-2014 01:21 PM
Cheapest Retaining wall diy4life Landscaping & Lawn Care 15 03-21-2012 10:18 AM
Retaining Wall Demolition --HOW? tdrumm Landscaping & Lawn Care 12 03-20-2011 02:32 PM
