Cannot Find 5/8" Sprinkler Elbow Fittings - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By SPS-1
Old 05-26-2018, 03:14 PM   #1
Rewards Points: 30
Cannot find 5/8" sprinkler elbow fittings
Hi All,
I moved into a house built in 1985. When fixing a broken sprinkler i noticed that the blue plastic L-shaped part that connects the sprinkler head to the pipe had broken (i think it's called the Riser fitting or Elbow Insert)
So i took it out to get a replacement, but i could not find the correct size anywhere. All stores (HD, Lowes, ace) carry 1/2" and 3/4" and 1" fittings, and none of these fit. After i measured the OD of the sprinkler pipe running underground, i found i needed a 5/8" fitting.
So what's the story? Have they stopped manufacturing 5/8" pipes and fittings for sprinkler systems? Any suggestions on where to get one?
HELP !!!
st_group is offline   Reply With Quote
Old 05-26-2018, 04:46 PM   #2
Rewards Points: 1,858
Re: Cannot find 5/8" sprinkler elbow fittings
Originally Posted by st_group View Post
Hi All,
HELP !!!
Reads a bit confusing to me but I'll try here....
If the o.d. of the pipe or tubing underground is 5/8" inch, then for a internal use barbed fitting as in the pic to fit in to it , then it will have to be a 1/2 ich o.d. barbed fitting. A 5/8" barbed fitting will not fit in a 1/2" inside diameter (5/8" O.D.) pipe/tubing.
Gregsoldtruck79 is offline   Reply With Quote
The Following User Says Thank You to Gregsoldtruck79 For This Useful Post:
st_group (06-10-2018)
Old 05-26-2018, 05:59 PM   #3
Rewards Points: 7,504
The poly-pipe used in sprinkler systems (at least the systems used around here) is not standard inside diameter. The barbed fittings you buy at HD plumbing department will not fit (too big, if memory serves me right). You need to find a landscape supply store that sells sprinkler supplies.
Gregsoldtruck79 likes this.
SPS-1 is online now   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
Old 05-26-2018, 07:07 PM   #4
Rewards Points: 188
Look for "funny pipe". The ID is different and will fit the sprinkler head fittings.
Dan
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
Old 05-26-2018, 07:14 PM   #5
"Funny Pipe" -- yeah that's what they called it. I was trying to remember what they called it, but the neurons just were not working tonight.
Old 06-10-2018, 12:30 PM   #6
Rewards Points: 30
Thanks everyone for your answers. I measured the inner diameter and it is indeed 1/2 inch. I guess i will get the 1/2" barbed fitting and try again. Earlier, I had taken a cutout of the pipe to the store before, and by eyeballing it, it did not seem that the 1/2" fitting would fit the pipe, but i guess i will try again.
Tags
elbow insert , fittings , riser , sprinkler
Sprinkler system Italgrl Landscaping & Lawn Care 3 05-22-2014 10:39 PM
Sharkbite Fittings davidblackwoods Plumbing 55 06-14-2013 08:14 PM
Why can't I find a good thatch rake or pine needle rake? carl1864 Landscaping & Lawn Care 5 06-05-2011 01:01 PM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 05:23 PM
locating buried sprinkler valves MrLinux Landscaping & Lawn Care 3 08-15-2009 12:50 AM
