Can Someone ID This For Me? Can I Remove It? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By Nealtw
  • 1 Post By vote4Pedro
  • 2 Post By vote4Pedro
Old 04-28-2019, 10:14 AM   #1
Rewards Points: 224
can someone ID this for me? can I remove it?
This thing has been attached to a outdoor outlets for sometime. The little holes on the side actually leaks water. when I turn the spout on. What does it actually do? can i remove?
vote4Pedro is offline   Reply With Quote
Old 04-28-2019, 10:22 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,628
Re: can someone ID this for me? can I remove it?
Anti-siphon (i.e vacuum breaker) hose bib.
Old 04-28-2019, 10:24 AM   #3
retired framer
Rewards Points: 20,436
It is ant-siphon. For when you have left the hose in a puddle and the city water is shut off and the water level in house gets so low that is pulls water out of that puddle.
If it will come off you can remove it or replace it.
Do not use flat bottom gables with scissor trusses.
Old 04-28-2019, 10:25 AM   #4
Rewards Points: 224
if it turn the spout on, water just comes out of the sides. does it mean it's broken?
Old 04-28-2019, 10:25 AM   #5
retired framer
You're getting faster.
Windows on Wash likes this.
Old 04-28-2019, 10:26 AM   #6
Rewards Points: 224
right now so much water comes out of it from the side that I end up getting sprayed soaking wet. seems very inefficient. Also doesn't seem to twist off easily so i'm trying to wd40 it for a bit
Old 04-28-2019, 10:33 AM   #7
retired framer
They don't leak when they are new. Some don't come off, I have pulled the guts out and tried to get part, with no luck.
I replaced the guts with a short piece of air hose and that worked once I got the length just right. Right now I don't remember how the guts come out.
Old 04-28-2019, 10:41 AM   #8
Oso954's Avatar
Rewards Points: 1,974
Most of those anti syphoning attachments have a set screw. It is often a breakaway set screw. (Turn it until it breaks off)
If you have a set screw, all the WD40 in the world isn't going to make it turn easier.
Depending on how it was installed, you run the risk of damaging the hose bib threads as you remove it.
https://www.lowes.com/pd/cash-acme-b...iABEgKdWPD_BwE
Oso954 is online now   Reply With Quote
Old 04-28-2019, 10:47 AM   #9
Rewards Points: 224
doesn't seem to have a set screw but boy is in in there tight.
Old 04-28-2019, 10:50 AM   #10
retired framer
I had one that would not come off.
Old 04-28-2019, 11:04 AM   #11
Rewards Points: 224
found the set screw under layers of dirt. it was perfectly smooth and hard to spot.. who the F thought this was a good idea is beyond me.
Nealtw likes this.
Old 04-28-2019, 01:22 PM   #12
Oso954's Avatar
I think the idea is the average homeowner won’t take it off and will call a plumber. The plumber is “required” to install a new anti siphon device.
If you have a dremal or a 4 inch grinder, you can cut the anti siphon device. Cut the threaded portion then use a screwdriver to pry open the split.
If the set screw is in the right place, you can drill out the set screw. However, they often end up where you cannot get a drill in at the right angle.
Old 04-28-2019, 03:51 PM   #13
Rewards Points: 224
got a dremal and cut out the piece and replace it with a new one. problem solved
lenaitch and Nealtw like this.
Old 04-28-2019, 03:57 PM   #14
retired framer
Success is always a good option.
How To Remove Rust Stains - Rust from Tools Flannel Guy DIY How To Guides 2 05-30-2017 02:15 PM
Want to remove wall in kitchen, possible? mikereno1 Building & Construction 7 11-11-2016 12:06 PM
can i remove Amitabh Building & Construction 0 06-08-2016 06:42 PM
How to remove shower pan? timnancyk Plumbing 17 01-11-2016 03:06 PM
need to refinish me pressure treated deck AND remove cabot SPF - NEED INPUT Kirchf Painting 0 05-27-2015 11:19 AM
