Burying Gutter Downspouts - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-20-2019, 12:10 AM   #1
Rewards Points: 80
Burying gutter downspouts
I plan on burying the gutter downspouts of my house, which sits on a fairly flat lot. The plan is to place a 12x12 catch basin underneath each downspout and run 30ft of 4" PVC pipe underground and away from the house and a pop-up emitter at the very end. I've read that the minimum pitch needed is 1/4"/foot. That means the end of the pipe will be at least 7 1/2" below the catch basin outlet, I'm afraid that this might be too low for the pop-up emitter? Please share your thoughts. Thanks.
cchean is offline   Reply With Quote
Old 07-20-2019, 12:19 AM   #2
retired framer
Rewards Points: 20,340
Re: Burying gutter downspouts
A catch basin near the house will be good for mosquitoes, 1/8" per foot should work, you could also just put in a dry well with the last so many feet of pipe perforated.
Do not use flat bottom gables with scissor trusses.
Old 07-20-2019, 08:09 AM   #3
Rewards Points: 6,122
During a heavy rain the amount of water coming off your roof will be extreme. With the catch basin that close if it overflows it will be right next to the house.
A flat (or almost flat) yard is a difficult place to drain water. Do you have any low areas on your property? Even the pop-up at the end needs some slope to move that water away.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 07-20-2019, 09:55 AM   #4
Hammered Thumb
Rewards Points: 2,038
Ditto on eliminating the catch basins, pipe the downspout direct with a PVC transition. Also agree can use 1/8"per ft, and if want, perforated the last 10' or so to drain out. Because of the 90d turn for the pop-up elbow, that may set up your slope for a flat grade right there. You'll get water sitting in the end, but a hole in the elbow drains that.
3onthetree is offline   Reply With Quote
Old 07-20-2019, 01:14 PM   #5
Rewards Points: 80
Thanks to all replies so far.
The reason I opted for the catch basins was that I read that the drain line could get clogged with leaves if connected directly to the downspouts. Eliminating them would be easier and cheaper, though.
I am not using the corrugated pipe. Instead, I am using 4" PVC pipe, three 10ft sections, connected using pvc primer and cement. Once i dig the trench, should I use gravel or just plain dirt to get the correct pitch?
Old 07-20-2019, 04:21 PM   #6
Hammered Thumb
If you got a lot of leaves your downspout inlet at the gutter will clog first. But with smooth wall pipe, any here and there will blow out. For me the first big rain every spring flushes them clean. Don't glue the pop-up cap so you can clean anything out if needed though.
With solid pipe, no gravel needed. With only 3 pipes, just set the slope at entry and exit, any overdigging lower along the way will be filled in by backfill, as long as you break up the dirt small enough to go under the pipe and tamp it a little. If you do use perforated the last 10' to dispose of some water, that will need gravel and a sock or fabric wrap.
Old 07-24-2019, 02:55 PM   #7
Rewards Points: 578
I would put in a NDS Flo-Well kit - price is $125 plus some gravel and your time but it holds 50 gallons of water and then slowly releases it into the ground around it.
https://www.ndspro.com/flo-well-kit.html
Calson is offline   Reply With Quote
