Bot New House - Part Fescue, Part Bermuda Lawn - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-22-2017, 10:26 AM   #1
Rewards Points: 14
Bot new house - part Fescue, part Bermuda lawn
Hi - we have a large lot with majority fescue. Though bermuda grass seems to taking over the lawn. Spoke with few folks and they advised that there's no way to remove bermuda.. eventually it will takeover the lawn. Need help, we'd like to retain fescue or some type which remains green year around.
Thanks, manud
manud is offline   Reply With Quote
Old 01-22-2017, 12:25 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Re: Bot new house - part Fescue, part Bermuda lawn
Thanks, manud
Ayuh,..... Before ya start worrin' 'bout the type of grass ya got, ya gotta deal with the drainage issues covered in this thread, 'n yer garage thread,...
My guess is, the lawns will need to be destroyed, 'n re-done, After the drainage isues are dealt with, so you can plant, or sod with whatever grass type ya want, Then,...
Old 01-22-2017, 02:58 PM   #3
RRH
Rewards Points: 1,336
Only one option. You use roundup and kill the lawn where ever there is bermuda.
Then plant fescue.
When you do this depends on what area of the country you live in. Again not enough info.
If you keep the bermuda it will be green in summer then in winter can seed in rye grass which will green then turn brown in summer.
But again depends on where you live
RRH is offline   Reply With Quote
Old 01-26-2017, 01:36 PM   #4
Rewards Points: 4,170
There is a trick to encourage an invasive species to take over when you have cool and warm season grasses where you water and fertilize only during the time the desired grass is growing and the other is dormant. In this case, you would water and fertilize in the fall and spring but not the summer. Whether it will keep a grass from being overtaken by an invasive species I do not know.
stick\shift is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Attaching wood fence to house TheCowGod Building & Construction 5 04-13-2012 03:57 PM
From fescue to Bermuda poolecw Landscaping & Lawn Care 6 09-17-2009 11:47 AM
My house is a project...Part II "Deck Evolution" tigerbalm2424 Project Showcase 21 07-24-2008 10:37 AM
Need to Jack up part of my house.... harleysilo Remodeling 24 10-01-2006 08:05 AM
