Blocking A House From Our View - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree24Likes
Old 02-08-2018, 05:04 PM   #16
Guapo
Rewards Points: 11,950
Re: Blocking a house from our view
We don't mind seeing that their house is there - we just don't like seeing ALL of it, if that makes sense.
So seeing half of the house would be ok? Would it be better if it were a different color? Any idea what the angle of the slope is? Better yet, can you post a pic from your window? So far, the best idea is the boulder although you might want to paint a mural on it.
Guap0_ is offline   Reply With Quote
Old 02-08-2018, 05:05 PM   #17
Rewards Points: 452
http://www.learn2grow.com/gardeningg...Elaeagnus.aspx
Do you live along a coastline? Try this terrific shrub! It tolerates high winds and other maritime forces, including salt-laden moisture. Even in a container, the hardy evergreen species are happy! And go ahead and try them by the pool: Chlorine exposure won’t stunt the resilient plant’s growth!
Few shrubs grow as fast as Elaeagnus, too, making this an excellent choice for hedges and green screens where you want to obscure a less-than-desirable view.
Makes for good neighbors. Of course, probably banned in Cali.
bg
yardmullet is offline   Reply With Quote
Old 02-08-2018, 05:08 PM   #18
Rewards Points: 1,550
To give an idea of the height you need, dig a post hole where a fence, boulders, antique signs or whatever would be, and set a 2x4 x ??? long in the hole. Back at your house sight across the distance and have someone mark an elevation on the 2x4 that would obscure the portion of the neighbor's house you'd not care to see.
Startingover and de-nagorg like this.
SeniorSitizen is offline   Reply With Quote
Old 02-08-2018, 05:36 PM   #19
Rewards Points: 12
Thanks for the responses! I'll look into that shrub - I know I have seen other people around town successfully grow small evergreens, so maybe it's possible!
Setting up a temporary post, to figure out how tall of a thing we need to build, is a great idea. It would definitely help for brainstorming to know what height we need! I'll have to try that...
Here's a picture! Please don't mind the peeling porch - we just moved in this winter and are definitely planning on taking care of that in summer.
Oh, and the ocean is frozen right now, so it really blends in with the sky... Haha, but it's there, I swear!
Thanks again.
Sinopa2 is offline   Reply With Quote
Old 02-08-2018, 05:44 PM   #20
Rewards Points: 1,938
More shrubs that will grow in Alaska.... http://www.alaskahardy.com/trees-shrubs.php
Gregsoldtruck79 is online now   Reply With Quote
Old 02-08-2018, 05:57 PM   #21
Guapo
Forget about the boulder idea unless you put it on the porch. That's the only way that it would work. I think that it's just the color of the house that's the problem. If it were white, it wouldn't be bad at all. Offer to paint it or pay 1/2 the cost to paint it white or a color of your choice.
Old 02-08-2018, 06:00 PM   #22
Rewards Points: 12
Hahaha totally agree! I don't mind it too much when it's covered in snow.
Old 02-08-2018, 06:17 PM   #23
Guapo
Ok then. that's your answer. Make a deal with the owner.
Old 02-08-2018, 07:19 PM   #24
If there is a prevailing wind you would like to slow to a dull roar rather than a gail wind, fences or tree rows can be arranged in a V pattern as the geese would fly.
When working in blizzards I've built temporary wind breaks using a pallet with 2 4x8 sheets of plywood with the V positioned to the wind of course. It is so calm inside the V a kitchen match can be lit. It seemed as if there was a negative pressure in the V.
Old 02-09-2018, 07:25 AM   #25
Guapo
I've always wondered about the term "negative pressure". Isn't the opposite of pressure vacuum? That's what's seen on some gauges.
Startingover likes this.
Old 02-09-2018, 07:34 AM   #26
retired framer
Rewards Points: 20,612
If you can light a match, that spot is neutral. Positive or negative pressure, you would have wind.
Old 02-09-2018, 09:34 AM   #27
After viewing the situation, it seems as if you could block the view with a man made snow ridge to whatever height you like for at least 6 months of the year.
de-nagorg likes this.
Old 02-09-2018, 10:21 AM   #28
EDIT: or you could build a row of 6 ft. tall snow men and decorate both sides so the good neighbors could enjoy them too.
Old 02-09-2018, 10:51 AM   #29
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Thanks again.
Ayuh,.... About Where, is the property line,..??
Old 02-09-2018, 12:01 PM   #30
Knows Enough to be Danger
Rewards Points: 1,219
I'm afraid whatever you do is gonna have to be really tall to block the house. Unless my mental angle is off.
It would be interesting to set something up temporarily. To see if this fence needs to be 8ft tall or 12ft tall!
NickTheGreat is offline   Reply With Quote
Questions on Construction of my House: Built in 1980's, questioning structural design ejumps Building & Construction 4 03-05-2016 05:55 PM
water mitigation around house tnprogrammer Building & Construction 4 02-22-2016 03:10 PM
Pros please help - what method attach porch roof to brick veneer dinoburger Concrete, Stone & Masonry 6 08-02-2015 10:57 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
