Big Tree Stump - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-06-2016, 05:35 AM   #1
Rewards Points: 934
Big tree stump
In the middle of installing pvc fence and once of the posts land right behind this big tree stump. Location is okay but we're hitting a lot of big roots from tree. We really dont want to grind the stump as we like it. Anyway to chop up these roots within diameter of post hole were digging? Would auger do it? Thanks
Sent from my SAMSUNG-SM-G935A using Tapatalk
Mstrlucky74 is offline   Reply With Quote
Old 04-06-2016, 06:13 AM   #2
Retired Moderator
Rewards Points: 7,174
Re: Big tree stump
I always have a Sawsall handy when digging post holes, it is the best tool I have found for getting roots out of a hole.
I also own a pike pole---heavy 6 foot long tool with a chisel point on the end--we have a lot of rocks in our area.
kwikfishron (04-06-2016)
Old 04-06-2016, 06:39 AM   #3
Property Mgt/Maint
Rewards Points: 6,564
Re: Big tree stump
A auger is not going to chop up roots. More likely it will deflect the auger and drill your hole off center. Small roots, (1" or smaller) might break or pull out. Anything larger use what Mike suggested.
A bar like this with a sharp end will cut the roots down in the bottom of a hole.
www.homedepot.com/p/Ludellc-70-in-17-lb-Tamper-Head-Digging-Bar-50010/204326727
or
http://www.homedepot.com/p/Bully-Too...-205348003-_-N
Yodaman is online now   Reply With Quote
Old 04-06-2016, 06:45 AM   #4
Rewards Points: 107
Eventually that stump is going to become Motel 6 for carpenter ants and Denny's for termites. Don't ask me how I know . Get rid of ot
jimn01 is offline   Reply With Quote
Old 04-06-2016, 07:01 AM   #5
Rewards Points: 934
Re: Big tree stump
Thanks guys....
Old 04-06-2016, 07:50 AM   #6
Rewards Points: 202
Re: Big tree stump
Yup, yup, and yup to what the guy's said. The auger isn't going to do it, in fact I can see where it could get you hurt if you persisted with it, but a reciprocating saw and bar with a chisel point work well. I've left a few stumps over the years to set flower pots on, and they're attractive for a while, but you do need to keep an eye on them because they do need to go sooner or later.
Tree Stump bubblegummom Gardening Forum 13 05-16-2014 10:50 AM
Tree Stump joeg679 Landscaping & Lawn Care 20 01-21-2013 08:54 PM
How to prevent tree stump from rotting? Jeremy Hillary Boob, PhD Landscaping & Lawn Care 8 06-21-2009 08:16 AM
Tree stump mdlbldrmatt135 Landscaping & Lawn Care 2 06-16-2006 01:31 PM
