Big Box (HD, Lowes) Grass Seed (Scotts) Vs Local "selected" Grass Seed (no Filler) - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-10-2017, 08:50 AM   #1
Rewards Points: 424
Big box (HD, Lowes) Grass Seed (Scotts) vs Local "selected" Grass Seed (no filler)
I'm on the fence between buying Scott's Grass Seed at the local Home Depot
or buying "selected" seed by a local Garden Center in NJ.
I just got off the phone with the owner of a local Garden Center who proclaims
that the Scotts seed that you buy at Home Depot etc is infused with "fillers"
and is therefore not as effective as his own "carefully" selected seed that he sells that has NO FILLER IN IT.
Is there a difference?
I have 3000 sq feet of a backyard with enough sunlight on it to fill with seed
after I till all of the weeds (90% of it is weeds) with a Tiller Machine, then seed
then throw some topsoil on top.
Thanks!
HTFreak is offline   Reply With Quote
Old 05-10-2017, 02:37 PM   #2
Rewards Points: 122
Re: Big box (HD, Lowes) Grass Seed (Scotts) vs Local "selected" Grass Seed (no filler
The only experience I have between a big box store vs a local "Garden Center" is when I purchase my winter rye seed each year I don't purchase the seed from the box store because I can get (in my opinion) just as good or better quality and it's priced much less at a lawn care distributor. I will say I've had very good results with Scotts Perennial Rye seed though.
Joeycarnuba is offline   Reply With Quote
Old 05-10-2017, 08:56 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 2,218
I've tried both over the years and frankly I can't tell the difference, although I will disclose I'm not that particular about my lawn. I find both will give you some weeds. The advantage with the garden centre is you can usually get custom mixes or simply mix-and-match from their bins and combine at home. On the other hand, Scott's etc. is more likely to go on sale at a retailer at certain times of the year. I just picked up some Scott's at almost half off.
lenaitch is offline   Reply With Quote
Old 05-10-2017, 10:12 PM   #4
Rewards Points: 4,356
Perhaps the "filler" he's talking about is the coating on Scott's to hold in moisture. I use Pennington because I like the coating that repels birds. But, with all the rain the coating became a soggy mess, but this year only.
If you have the time, you could try a small bag of each & grow a little in a small tub under good conditions. That will tell you which grass seed works better for you.
Nik333 is offline   Reply With Quote
Old 05-11-2017, 06:38 AM   #5
ZTMAN's Avatar
Rewards Points: 342
If you read the grass seed bag it will tell you filler percentage. Generally, the lower the price, the more filler.
If I was doing that big of an area, I would probably go with the local guy, if he guarantees his seed.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 05-11-2017, 09:13 AM   #6
Rewards Points: 4,170
The local guy might also have a better mix for your area.
As I mentioned in your other post, please kill the weeds before you till or they will be back in short order.
stick\shift is offline   Reply With Quote
Anyone have any luck with Scotts grass seed? Piedmont Landscaping & Lawn Care 34 05-14-2013 09:20 PM
Scotts EZ Seed. No go. DrHicks Landscaping & Lawn Care 13 05-12-2011 05:30 PM
Grass Seed is Not Generic - Get the Right Blend user1007 Landscaping & Lawn Care 7 04-29-2011 12:15 PM
New grass seed planted- next steps to fix problems? skittles1984 Landscaping & Lawn Care 9 03-13-2011 10:49 AM
grass seed rcassidy Landscaping & Lawn Care 2 02-27-2009 06:03 PM
