Best Way To Uproot A Tree Without Killing It? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-26-2015, 02:44 PM   #1
Rewards Points: 323
Best way to uproot a tree without killing it?
I have two trees in the back yard that are near the edge of my koi pond. I'd like to uproot and relocate them a to about 5 yards away. They'rr not that big, maybe 8ft tall ith small branches and bodies. Last time I uproot a similar size tree it died
Merci Beacoup!
johnv713 is offline   Reply With Quote
Old 03-26-2015, 03:23 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Ayuh,.... It's done with a Tree Spade,....
Hirin' it done, or rentin' might be an option,.....
Old 03-26-2015, 03:33 PM   #3
Rewards Points: 736
WOW. That is a machine.
8 ft is pretty big. For small stuff you basically want ot get as much of the root as possible, and bring as much of the soil around the root into the new hole as possible. The bigger the tree the harder both of those things are, unless you have that doomsday machine that Bondo recommended
TheBobmanNH is offline   Reply With Quote
Old 03-26-2015, 03:36 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 9,346
Merci Beacoup!
Look at what is above ground....that is about how much is below ground.
At 8', I would suspect you need to dig up a root ball that is at least 3' in dia and about 3' deep.
I'm the ultimate DIY guy....but this might be beyond the average DIY scope due to required equipment.
Your other issue....this should have been done before now. If the trees are starting to bud, you risk killing them.
Old 03-26-2015, 05:00 PM   #5
Rewards Points: 323
Sorry I meant to say 5 ft... Hundred of small roots underground too. Should I water as soon as it's transplanted?
Old 03-26-2015, 05:08 PM   #6
Rewards Points: 45
I'm sorry but that is not true at all.
To the OP, it's a gamble. For the perimeter of the hole go outside of the drip line(canopy) of the tree. That 3' depth mentioned would probably be good for that height of a tree. What is the species?
jegolopolli is offline   Reply With Quote
Old 03-26-2015, 05:28 PM   #7
Rewards Points: 323
Not sure what's it called but here's a picture. My woman said to chuck it but a lover of any living thing Id rather save it. I think I'm going to water it asap.
Old 03-26-2015, 05:37 PM   #8
Rewards Points: 4,428
I thought you really meant a tree, not a bush..
ron45 is online now   Reply With Quote
Old 03-26-2015, 05:41 PM   #9
Rewards Points: 323
Hey this is a family board 😜
Old 03-27-2015, 12:53 AM   #10
That's not a tree is it, looks more like a bush.?
Really, did you see what Bondo posted.?
Old 03-27-2015, 03:06 AM   #11
Rewards Points: 750
Bush is a family, a few of them were even president XD
Hick is offline   Reply With Quote
Old 03-27-2015, 12:37 PM   #12
Rewards Points: 323
Bush as in down below lol. Sorry I got a dry sense of humor
Yes I click on Bondo's link. I think they used that somewhere in SE Asia recently to remove and transplant tons of trees on an existing road to widen it.
Not trying to get into politics here but IMHO the last pres with some integrity and decently was Reagan. All of the recent ones are all about the Benjamins, pun intended
Old 03-27-2015, 12:55 PM   #13
JOATMON
ddawg16's Avatar
And that is not true either.
I guess I should have been a bit more clear. No, the roots will not look like the top of the tree, but there will essentially be as much mass below as there is above....just spread out a lot more. Depending on soil type, the roots may or may not be deep. In most cases the roots tend to spread out from the tree staying close to the surface where they get more oxygen and water. But some are still deep (if the soil permits it)
Here is a good link on it.
http://www.deeproot.com/blog/blog-en...ts-really-grow
Old 03-27-2015, 04:40 PM   #14
Rewards Points: 45
Right, the roots stay more towards the top of the soil where most of the uptake is taking place. Your post made it seem like you meant depth not mass, that's where I was confused. But, there is still less mass underground than what is above ground. I am to trying to argue with you, just trying to be clear. Btw, I am an ISA Certified Arborist who like you references the internet lol
The Following 2 Users Say Thank You to jegolopolli For This Useful Post:
ddawg16 (03-27-2015), Leprechaun (04-13-2015)
Transplant tree near underground utility lines? BrandonC_1972 Landscaping & Lawn Care 11 08-26-2012 05:43 PM
Apple Tree Care bgibson11 Landscaping & Lawn Care 9 05-28-2011 08:28 AM
Extending deck around a tree jcgoldie Building & Construction 2 02-15-2011 05:20 PM
Tree Stump Killing Grass? malsup Landscaping & Lawn Care 3 12-14-2007 08:24 AM
