Best Way To Divert A Downspout - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-11-2014, 10:16 PM   #1
Rewards Points: 752
Best Way to Divert a Downspout
I have just moved into a home and the end of a downspout has been taken off. As you can see from the picture, the downspout ends over the top of a flower bed and is next to my driveway.
Any ideas as the best way to divert the the end of the downspout? I'm assuming that the previous owner took off the end because of the direction that the water was flowing(?). Maybe washing out the rocks in the bed or out to the driveway and would create a sheet of ice in the winter? Any other ideas on the best way to address this? Thanks.
Best Way to Divert a Downspout-downspout.jpg   Best Way to Divert a Downspout-downspout1.jpg
kennykenny is offline   Reply With Quote
Old 09-12-2014, 09:15 AM   #2
Rewards Points: 17,914
There is no great way to do it now since the walks already in place.
Any low area out near the street for storm drainage?
One of the homes I own is sitting on a slab that was pored to low and the yard has no grade sort of what yours looks like.
I had to resort to installing a French drain and a sump pit with a sump pump. There's a 1-1/2" PVC running out to the street.
Works perfect.
And yes it's possible to still run the line under that walk with no damage.
Old 09-12-2014, 10:28 AM   #3
Rewards Points: 2,378
Perhaps move the downspout to the other end of the gutter?
bob22 is offline   Reply With Quote
Old 09-12-2014, 11:25 AM   #4
Rewards Points: 752
If moving it to the other end of the gutter, what do you do with the existing hole that is there from the current downspout? Thanks!
Old 09-12-2014, 11:27 AM   #5
Rewards Points: 752
Joe,
Is there an "easy" way of putting the drainage under the sidewalk?
Old 09-12-2014, 12:15 PM   #6
Rewards Points: 6,652
Originally Posted by kennykenny View Post
Joe,
Yes. It will mean removing rock, so you can dig a trench to get a line underneath the Sidewalk on the lawn side. Keep in mind that if you live in a Freeze zone. Any water that is not allowed to drain from the line, can cause an Ice Dam.
Old 09-13-2014, 07:10 PM   #7
A Little Of Everything
Rewards Points: 1,418
I'd run it down the driveway. The number of times that that'll leave a sheet of ice on the driveway is minimal.
DrHicks is offline   Reply With Quote
Old 09-14-2014, 05:56 AM   #8
stevergee's Avatar
Rewards Points: 73
Running it down the driveway would be my first approach since it would be very simple and the least disruptive.
Like DrHicks mentioned ice forming on drive way could be very seldom if any. And if it does you could always throw some salt rock on it while you are doing the side walks
stevergee is offline   Reply With Quote
Old 09-15-2014, 04:06 PM   #9
Have it drain into a rain barrel. When the barrel gets full, simply attach a garden hose to it and water your plants, or drain it to a lower elevation.
BrianN is offline   Reply With Quote
Old 09-20-2014, 12:08 PM   #10
Rewards Points: 2,800
A subterranean pipe or channel is not a good idea if the water, once down there, doesn't drain quickly to yet someplace, anyplace, else.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 09-20-2014, 12:14 PM   #11
You put a patch over the hole.
Decommissioning the downspout and putting a downspout elsewhere usually does not work out well because the gutter is usually sloped a little and water will collect and breed mosquitoes up in the gutter where the old downspout used to be.
Old 09-20-2014, 12:49 PM   #12
Ideally the patch includes a piece of sheet metal for rigidity's sake.
Old 09-20-2014, 06:42 PM   #13
Rewards Points: 12
I am going to post a link so I had to make one post to be allowed to post them.
It won't let me post links but you tube has plenty of ideas.
how to install a pop up drain in your lawn.
Motown 454 is offline   Reply With Quote
Downspout over lower roof smcclana Roofing/Siding 8 06-13-2018 05:01 PM
Need help with extending my downspout underground... DIYguy2000 Landscaping & Lawn Care 1 09-11-2014 01:25 PM
Downspout on sidewalk in front of the house nohandyman2014 General DIY Discussions 8 06-27-2014 08:26 PM
Should I add a downspout? scottyv81 Roofing/Siding 5 05-09-2012 07:37 PM
Replacing patio - Relocate downspout slvrbullet98 Landscaping & Lawn Care 2 05-08-2009 08:30 AM
