Best Rotor Drive Sprinkler Head - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-05-2015, 10:40 AM   #1
Rewards Points: 145
Best rotor drive sprinkler head
I can cover my front and backyard with 2x 30' radius 180 degree motor drive heads. I'm currently using a orbit hooked up to a hose. Is the rain bird 5000 the best spray for 10-30' range? Is prefer better near range vs distance.
1/2" lines @ 90psi.
Thanks.
kjmass1 is offline   Reply With Quote
Old 09-05-2015, 01:58 PM   #2
Rewards Points: 188
How big is the area? The arcs should overlap.
Dan
djlandkpl is online now   Reply With Quote
Old 09-05-2015, 02:31 PM   #3
Rewards Points: 145
It's roughly 40' x 15' or so. Obviously 4 rotors in the corners would be ideal but I'm trying to find a compromise with 1 or 2. Rain bird's "rain curtain" I was hoping would help solve the overlapping issues.
Old 09-05-2015, 02:42 PM   #4
Rewards Points: 188
You won't be happy with the results. Also 1/2 won't supply 2 heads at the same time unless you run each head on a dedicated line.
Dan
Old 10-28-2015, 09:21 AM   #5
Rewards Points: 145
My install worked pretty well with 1/2" poly at 60psi. Head to head coverage with the 2 rotors works pretty well in my oval-ish small lawn. I was also able to run 6 pop up 6" spray rotors with 8' half circle spray heads. For this I ran a main to the middle then split off each side of 3 heads.
While not perfect, it satisfies my lawn for about $300. Zones do need to run longer to achieve an 1" per watering.
The Following User Says Thank You to kjmass1 For This Useful Post:
djlandkpl (10-28-2015)
Adding a few sprinkler heads to existing argh Landscaping & Lawn Care 10 03-16-2018 11:31 AM
Sprinkler conversion from spray head to drip kevinf. Plumbing 3 04-25-2013 02:02 PM
sprinkler head stuck wont come up tven Plumbing 14 04-13-2013 01:25 PM
Sprinkler leak segal Landscaping & Lawn Care 5 03-11-2013 08:53 PM
ceiling tile replacement around sprinkler head LanterDan General DIY Discussions 4 10-29-2009 06:39 PM
