Best Approach To Removing Multiple Trunk System? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-04-2013, 03:38 PM   #1
Rewards Points: 625
Best approach to removing multiple trunk system?
I've gotten these 3 plants/trees down to these multiple trunk/stump nightmares and have showered them with herbicide. I'd appreciate any advice on the best approach to removing them from here.
Thanks!
#1 BEFORE
#1 AFTER
#2
#2 close up
#3
#3 close up
a1481155 is offline   Reply With Quote
Old 03-04-2013, 05:25 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 490
Ayuh,.... Take yer pick, a pick-ax, 'n shovel, or a hyd. hoe....
Bondo is online now   Reply With Quote
Old 03-04-2013, 08:30 PM   #3
r0ckstarr's Avatar
Rewards Points: 82
Start digging and cutting roots from the stumps as you uncover them.
r0ckstarr is offline   Reply With Quote
Old 03-04-2013, 08:44 PM   #4
Rewards Points: 18,448
Someone with a back hoe, mini escavator could have all that out as well as the roots in about 1/2 hour.
Buying a used AC system. forJAT HVAC 3 12-17-2011 09:52 AM
Need help with finishing touches on radiant heat system gbwillner HVAC 6 12-03-2011 11:16 AM
Installing Pool System New v. Used? flowerchick General DIY Discussions 5 10-27-2011 07:28 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
