Band S 5 Hp Tiller Want Start - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-07-2011, 04:09 PM   #1
Band S 5 hp tiller want start
have 5 hp tiller want start made by landmark its probably pretty old if i put gas in carb runs till gas is gone i really don t want to take carb apart its on tank any suggestions appreciated
thanks
cbjr6161 is offline   Reply With Quote
Old 07-07-2011, 04:58 PM   #2
Rewards Points: 2,512
If it is old and isn't running without pouring gas into it I'd say the carb is dirty and needs to be cleaned. If you don't want to do that, you'll have to serve as the carb and continue to pour gas into it to keep it running. Your choice is obvious.
bob22 is offline   Reply With Quote
Old 07-08-2011, 07:26 PM   #3
took carb apart changed seal emptied gas tank an d cleaned it out sprayed cleaned everything with carb cleaner put back together still want start plug is good still starts by putting gas in carb what else could it be
Old 07-08-2011, 08:33 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Clogged fuel line/filter???
Clogged cap vent???
Pinched, cracked, broken, fuel line???
XXX
Old 07-09-2011, 09:44 AM   #5
What kind of engine in this machine? Did the carb have a float? Was it very dirty when you cleaned it? Sometimes carbs need to be soaked to get old varnish etc to breakdown.
The Following User Says Thank You to bob22 For This Useful Post:
tpolk (07-09-2011)
Old 07-09-2011, 10:17 AM   #6
Household Handyman
Rewards Points: 1,412
"Older Landmark tiller with a 5 HP motor", this sounds as if it may have a Briggs & Stratton horizontal shaft motor where the gas tank is located under the carb. IF SO: there is a diaphragm located on the side of the carb which will go bad just sitting around for a short period of time. This little rubber diaphragm is the fuel pump, pulling fuel from the tank and pushing it into the carb. Do yourself a favor and purchase a repair manual for you brand and HP motor. There will be an entire chapter on carbs which will most likely show this set-up. A new diaphragm will cost under $2 and will make a world if difference in this motor's performance.
The Following User Says Thank You to Thurman For This Useful Post:
tpolk (07-09-2011)
Old 07-09-2011, 08:59 PM   #7
yes i did change the diapram your right corb sits on gas tank ccleaned out tank cleaned carb put it back together still doesn t work on its own
Old 07-15-2011, 10:19 AM   #8
how do u check if the vacumm is working on carb
compressor wants to start but won't wetbar HVAC 13 06-17-2010 07:15 PM
Homelite weedeater won't start. Out of ideas. Jasnall Landscaping & Lawn Care 7 06-03-2010 02:12 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Tools 2 08-26-2009 09:26 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Landscaping & Lawn Care 3 08-13-2009 11:58 AM
How to repair/clean centrifugal start switch pointertopica Electrical 4 12-03-2008 08:05 PM
